Hello Guest it is November 22, 2026, 03:10:30 PM
Author Topic: corel draw 12  (Read 18673 times)
corel draw 12
« on: December 30, 2005, 07:20:07 PM »
Art
If it was posible too import a DXF file from Corel Draw 12 into Mach 3 life would be a lot easier. I have found a work around but I can't use layers with the
work around.
I save as an Autocad 10 then open up the file in Turbocad learning edition then move the file to were it should be located in Mach 3 then exit and then save
as a turbocad file. It will then load in Mach 3 DXF import.  I will send a simple file that you can look at.
Thank You
Clay
Re: corel draw 12
« Reply #1 on: January 04, 2006, 05:08:45 PM »
Hello,
I have a  custom DXF export written in VBA for CorelDraw 12.  It is currently posted on the SheetCAM group in my files folder 'jemmyell'.  It is open source and I would welcome further development on this.
-James
