Hello
Guest
it is
November 26, 2026, 02:07:47 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
corel draw 12
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: corel draw 12 (Read 18704 times)
c1nel2
4
corel draw 12
on:
December 30, 2005, 07:20:07 PM »
Art
If it was posible too import a DXF file from Corel Draw 12 into Mach 3 life would be a lot easier. I have found a work around but I can't use layers with the
work around.
I save as an Autocad 10 then open up the file in Turbocad learning edition then move the file to were it should be located in Mach 3 then exit and then save
as a turbocad file. It will then load in Mach 3 DXF import. I will send a simple file that you can look at.
Thank You
Clay
jemmyell
106
Re: corel draw 12
Reply #1 on:
January 04, 2006, 05:08:45 PM »
Hello,
I have a custom DXF export written in VBA for CorelDraw 12. It is currently posted on the SheetCAM group in my files folder 'jemmyell'. It is open source and I would welcome further development on this.
-James
-James Leonard
www.DragonCNC.com
www.LeonardCNCSoftware.com
www.CorelDRAWCadCam.com
Print
Pages:
1
Go Up
« previous
next »
