Hello Guest it is October 31, 2026, 12:36:21 PM
Author Topic: thc300 install  (Read 18864 times)
thc300 install
« on: August 26, 2008, 08:40:15 PM »
hello all,
I am in the process of installing the thc300  file set into mach3.
  I  have copied all the associated files and bitmaps as suggested by  bob campbells  installation  instructions  but when i run the "thc300m3"  profile  I have no screens or buttons!!!
Am i doing something wrong??
thanks  in advance for any help
Re: thc300 install
« Reply #1 on: August 27, 2008, 01:23:03 AM »
Sounds like they are in the wrong directory, can you attach the screen set you are using and also say which buttons you cant see and I will see where they should be.
Re: thc300 install
« Reply #2 on: August 27, 2008, 05:54:05 AM »
Hood is there a directory map any where? sometimes I get it messed up to...
Hey THANKS 4 all the help in advance. I'll need more than you'll ever expect!!!
www.cravenpottery.com
Re: thc300 install
« Reply #3 on: August 27, 2008, 08:01:07 AM »
Make sure you go to views and choose which screenset you would like Mach to use(thc-300xx).  I encountered the same thing.  After installing the THC-300 screenset and you re-start, everything is blank.
Re: thc300 install
« Reply #4 on: August 27, 2008, 01:04:40 PM »
 Custom screensets can have there own locations for storing the bitmaps etc, the standard stuff is in Mach3\Bitmaps. If you have a screen that you dont know where to put the bitmaps you can open the screen set with screen4 and double click on a button and you will see the path for the image.
Re: thc300 install
« Reply #5 on: August 27, 2008, 09:14:22 PM »
wlarry  -=- that was my issue   thanks for the info !!!
