Hello Guest it is November 01, 2026, 11:56:38 AM
Author Topic: autocad vs. lazycam  (Read 13512 times)
autocad vs. lazycam
« on: August 20, 2008, 09:23:38 AM »
How can open a DXF file onto LazyCam after was made out in Autocad
I did click OpenDXF in LazyCam but No Entities Found...
uuccimi - novice
Re: autocad vs. lazycam
« Reply #1 on: August 20, 2008, 09:57:05 AM »
Did you close your dxf file that AutoCad created?  If the file is still open, it won't load into LC.
Bob@BobsShop - Been there done that.
« Reply #2 on: August 20, 2008, 10:34:43 AM »
Ok, I did close autocad, try to open with Lcam, but won't load any thing and see 2749.87 scale number in the blue screen
uuccimi - novice
« Reply #3 on: August 20, 2008, 10:50:58 AM »
Save as V12 .dxf from AutoCAD and try that.
« Reply #4 on: August 20, 2008, 11:46:43 AM »
Thanks ger21
V12.dxf  works!!!
uuccimi - novice
