Hello Guest it is November 13, 2026, 06:31:46 PM
Author Topic: Is it true about Galil plugin?  (Read 135637 times)
Re: Is it true about Galil plugin?
« Reply #20 on: July 15, 2008, 06:30:11 PM »
WE will need to change your scrip to make it home one axis at a time.. This has been tested on many machines so it "should" work.... Also please tell me if you see the LED for Axis home change to Green.
And please do as the previous post suggested and try homing them one axis at a time.
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #21 on: July 15, 2008, 06:36:11 PM »
Yes they do go green if I home one axis at a time..
Thank you VERY MUCH for your help....
Hey THANKS 4 all the help in advance. I'll need more than you'll ever expect!!!
www.cravenpottery.com
« Reply #22 on: July 15, 2008, 07:41:20 PM »
Okay.. So now we need to see what is in your ReffAll Button..  Do you have any Reffcombination() in the button script or and OEM code that makes them all home at the same time? We should be able to make this work with the following code for you :
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
Please have this VB code in the button and it should make it so you can have one button home the machine .
Brian
www.machsupport.com
« Reply #23 on: July 15, 2008, 07:56:26 PM »
will check tomorrow.... 530am comes quick.... Thanks again for all your HELP...
« Reply #24 on: July 16, 2008, 03:54:35 PM »
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
 this is what the button script was already?
What do the numbers reprasent? is it 24=Z,23=X, 22=YAnd25=A.... A does not have a switch...
« Reply #25 on: July 16, 2008, 04:39:07 PM »
Hello,
Yes that is correct for the Axis numbers..
IF you would like you can delete the one for the A axis..
Brian
www.machsupport.com
« Reply #26 on: July 16, 2008, 05:08:55 PM »
Would that affect it?
« Reply #27 on: July 16, 2008, 09:12:10 PM »
It should not try to home the axis if you do not have it selected in Ports and pins..  So there should be no effect ;)
Brian
www.machsupport.com
« Reply #28 on: July 17, 2008, 05:11:45 AM »
So your saying that is will not work, because it already had what you wanted me to change it to?
« Reply #29 on: July 17, 2008, 06:06:28 AM »
Homeing the A axis is the DoButton 25 line. If you don't want it to try to home the a axis you can make sure you either delete that line in the button script or Make sure the a axis home switch isn't enabled in ports and pins.
