Hello Guest it is November 13, 2026, 05:56:59 PM
Author Topic: Is it true about Galil plugin?  (Read 135590 times)
Re: Is it true about Galil plugin?
« Reply #30 on: July 17, 2008, 11:05:54 AM »
Ok we kind wondered off...
I want to use one button to home 3 axis. XY and Z. I have the ports and pins set correctly, including the A it is not activated in mach.
The problem is if you referance 1 axis at a time you can get through all 3, but if you ref all home it will start the sequance and then after hitting the Z home, it refuses to go any further...
All axis are still active with galil, there is no galil fault.
If I hit the ESC key it will not continue because the sequance was stopped.. If you hit ref all home again it will back off the switch and stop.. Then I haave to hit ESC again... It will do the samething with X then Y...
You can ref all home if you do it 1 axis at a time, in the setting screen.... No problems at all that way...
It is not really a problem if I can not get the ONE button approach to work, UNLESS the problem can be somewhere else??? Like refrancing during a tool change(manual), during a long program just to make sure 100% each segment is correct... It is a really pain to have a 12, 18, or even a 24 hour program loose position...
Hey THANKS 4 all the help in advance. I'll need more than you'll ever expect!!!
www.cravenpottery.com
« Reply #31 on: July 17, 2008, 11:32:50 AM »
Hello,
I have a Galil here and a router that I run it with .. I will connect it up and home the machine and tell you if I see any trouble here. This has worked in the past and I have no idea why it is not working for you now.. So if you could please be sure you are running rev 3.041 and I will see if I can have it happen to me.
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #32 on: July 17, 2008, 02:28:38 PM »
R2.63, I am updating...
« Reply #33 on: July 17, 2008, 03:49:20 PM »
Thaty was to easy.... Something has to go wrong...... at least once...LOL..
Thanks MUCH,
Marc Craven
« Reply #34 on: July 17, 2008, 10:11:09 PM »
Okay, Do I need to test for any other problems that you are seeing with the homing?
Brian
www.machsupport.com
« Reply #35 on: July 18, 2008, 03:44:46 PM »
Not yet....
Not sure how to thank you for all your help... BUT THANKS>>>THANKS...
« Reply #36 on: July 24, 2008, 01:00:03 PM »
Mine still hangs every now and then after updating to R3.041. It seems to do it less if I home V and U first.
Darek
« Reply #37 on: July 24, 2008, 03:55:11 PM »
I think it maybe related to a program end?
What exactly is the best program end???? that'll stop any modal functions, that could still be active?
« Reply #38 on: July 24, 2008, 04:09:42 PM »
I've seen the cancellations commonly addressed in the Initialization string of the program.
I suppose you could include them in the M30 macro, or make up a custom macro to suit.
You can set a few to M30 in Config.
Just thinking out loud here.
RC
« Reply #39 on: July 24, 2008, 06:41:47 PM »
I was refering to the homing sequence hitting the home switch and not backing off. Not sure if the Modal state of G codes would apply to this. I am also homing the axis one at a time with different buttons.
Darek
