Hello
Guest
it is
November 13, 2026, 06:22:15 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
Galil
(Moderators:
smurph
kcrouch
Is it true about Galil plugin?
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: Is it true about Galil plugin? (Read 135618 times)
Brian Barker
3,860
Re: Is it true about Galil plugin?
Reply #20 on:
July 15, 2008, 06:30:11 PM »
WE will need to change your scrip to make it home one axis at a time.. This has been tested on many machines so it "should" work.... Also please tell me if you see the LED for Axis home change to Green.
And please do as the previous post suggested and try homing them one axis at a time.
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
pointcloud
90
Reply #21 on:
July 15, 2008, 06:36:11 PM »
Yes they do go green if I home one axis at a time..
Thank you VERY MUCH for your help....
Logged
Hey THANKS 4 all the help in advance. I'll need more than you'll ever expect!!!
www.cravenpottery.com
Brian Barker
3,860
Reply #22 on:
July 15, 2008, 07:41:20 PM »
Okay.. So now we need to see what is in your ReffAll Button.. Do you have any Reffcombination() in the button script or and OEM code that makes them all home at the same time? We should be able to make this work with the following code for you :
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
Please have this VB code in the button and it should make it so you can have one button home the machine .
Brian
Logged
www.machsupport.com
pointcloud
90
Reply #23 on:
July 15, 2008, 07:56:26 PM »
will check tomorrow.... 530am comes quick.... Thanks again for all your HELP...
Logged
pointcloud
90
Reply #24 on:
July 16, 2008, 03:54:35 PM »
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
this is what the button script was already?
What do the numbers reprasent? is it 24=Z,23=X, 22=YAnd25=A.... A does not have a switch...
Logged
Brian Barker
3,860
Reply #25 on:
July 16, 2008, 04:39:07 PM »
Hello,
Yes that is correct for the Axis numbers..
IF you would like you can delete the one for the A axis..
Brian
Logged
www.machsupport.com
pointcloud
90
Reply #26 on:
July 16, 2008, 05:08:55 PM »
Would that affect it?
Logged
Brian Barker
3,860
Reply #27 on:
July 16, 2008, 09:12:10 PM »
It should not try to home the axis if you do not have it selected in Ports and pins.. So there should be no effect
Brian
Logged
www.machsupport.com
pointcloud
90
Reply #28 on:
July 17, 2008, 05:11:45 AM »
So your saying that is will not work, because it already had what you wanted me to change it to?
Logged
Chaoticone
5,624
Precision Chaos
Reply #29 on:
July 17, 2008, 06:06:28 AM »
Homeing the A axis is the DoButton 25 line. If you don't want it to try to home the a axis you can make sure you either delete that line in the button script or Make sure the a axis home switch isn't enabled in ports and pins.
Logged
If you could see the things I have in my head, you would be laughing too.
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
