Hello
Guest
it is
November 08, 2026, 12:22:52 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Changed computers, can't get kboard working. Help!
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
Go Down
Author
Topic: Changed computers, can't get kboard working. Help! (Read 137420 times)
iqchallengedd
64
Re: Changed computers, can't get kboard working. Help!
Reply #50 on:
June 22, 2008, 07:44:10 PM »
No. I doesn't respond to MDI. It did when this sad tale began a few hours ago. The keyboard wouldn't work but it would respond to commands typed in. However, the DRO does reflect a lift of one inch of the Z even though it never happened. I did hear a stepper thud.
iqchallengedd
64
Reply #51 on:
June 22, 2008, 07:46:02 PM »
PS: I did set up the icon on the desktop. And I pasted in the edit.
Carnoustie, Scotland
Reply #52 on:
June 22, 2008, 07:47:04 PM »
Ok, can you check at the breakout board end of the cable, disconnect it and put a voltmeter between the Dir pin of the X axis and one of the ground pins. When you jog one way the meter should be 0v, jog the other and it should change to 5v.
iqchallengedd
64
Reply #53 on:
June 22, 2008, 07:49:12 PM »
Gonna look for an image of a cable on Google. If you need to go we can pick it up tomorrow or whnever.
Reply #54 on:
June 22, 2008, 07:51:40 PM »
Here you go
iqchallengedd
64
Reply #55 on:
June 22, 2008, 07:52:04 PM »
Does this look right?
iqchallengedd
64
Reply #56 on:
June 22, 2008, 07:53:42 PM »
Your just too fast for me. While I get my voltmeter can you tell me which 2 pins?
Reply #57 on:
June 22, 2008, 07:53:54 PM »
Yes but the one in the Mach manual is better
Reply #58 on:
June 22, 2008, 07:55:50 PM »
depends what you have set in your xml, look at your ports and pins, motor setup and you wil see what the Dir pin for X is. any pin from 18 to 25 is the zero volt or ground as I called it (wrongly of course)
iqchallengedd
64
Reply #59 on:
June 22, 2008, 07:56:06 PM »
TAking the cable lose won't blow a Gecko will it?
Print
Pages:
1
2
3
4
5
6
7
8
9
Go Up
« previous
next »
