Hello Guest it is October 20, 2026, 10:46:36 PM
Author Topic: Changed computers, can't get kboard working. Help!  (Read 135879 times)
Offline Kristin D
  •  203 203
  • Take that you LazyCam, next stop the glue factory!
Re: Changed computers, can't get kboard working. Help!
« Reply #80 on: June 22, 2008, 08:33:56 PM »
I will hang in for a while if you want to keep going. Too hot for dinner yet, and there is a sink full of dirty dishes I don't want to attack till it cools off.
Kristin
« Reply #81 on: June 22, 2008, 08:35:13 PM »
I'll be here for a while too. Can you post your XML? I have sent you a personal message as well.
Offline Kristin D
  •  203 203
« Reply #82 on: June 22, 2008, 08:39:02 PM »
I'm gonna pack it in too Kristin. I hear my wife upstairs loading her gun. Thanks for you interest and your help.
Mine is allways loaded, it's when you hear the slide pulled back it's time to worry. Sure you will sort this out soon. Worst case is remove Mach completley and reload with your setup file again from the other PC, I had a wierd problem a few weeks back where if I opened Mach, moved the mouse everything locked up and I had to remove the program fully, just reloading it over the old did not fix it.
Kristin
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #83 on: June 22, 2008, 10:19:52 PM »
Hi, Iqchallengedd
Things can get out of Whack with Mach3's driver sometimes, Probably best to remove it and reinstall at this point.
Open Device Manager, Rt click on Mach3 Driver, Select "Uninstall" Mach3 Driver, Yes.
Return to Mach3 Folder, C:\Mach3 and "Run" the "Driver Test", It will return with the "Driver Installed",  Reboot/Re-start Computer Required.
Restart and run Mach3, From time to time this has been the only solution for Me.
You now after Using, Your Fore-Head to Drive 16 Penny Nail's in the Wall a few times.
Hope this Helps, Chip
« Last Edit: June 22, 2008, 11:12:20 PM by Chip »
« Reply #84 on: June 23, 2008, 06:54:09 AM »
Hey guys. I was signed off after the last tip from Kristen and Chip. I will try that later today and see what happens. Doesn't bother me a bit to find a simple cure after hours of trying. I just appreciate the support. I paid a mere $150 or so for Mach and get all the support in the world. I just bought a new Mac computer and haven't yet been able to find any help in installing the printer.
« Reply #85 on: June 23, 2008, 06:59:14 AM »
Can you post your xml and we can have a look and see if anything is wrong in it. Dont think there can be as it worked before but you never know.
« Reply #86 on: June 23, 2008, 08:01:19 AM »
Good morning Hood. You couldn't have gotten much sleep. I'll have to come and go this morning. Here is the XML (I hope).
« Reply #87 on: June 23, 2008, 12:31:50 PM »
Cant see anything glaringly obvious in your XML so suppose its down to the checks that that have been suggested  laterly. You mentioned a printer, dont suppose its an old parallel port type is it? If so see if that works on the port.
