Hello Guest it is November 26, 2026, 05:42:15 AM
Author Topic: Changed computers, can't get kboard working. Help!  (Read 138787 times)
Re: Changed computers, can't get kboard working. Help!
« Reply #10 on: June 22, 2008, 05:02:43 PM »
It looks like Mach gives you a choice of two addresses. One begins with 378, the other with 278. The number of the one in this computer might be 828 if I follow what you're saying. I'm going to shut this thing down (along with my email) long enough to check the properties on my old computer.
« Reply #11 on: June 22, 2008, 05:04:34 PM »
Roger. I'll check.
« Reply #12 on: June 22, 2008, 05:05:44 PM »
Did you use the xml from your last computer?
« Reply #13 on: June 22, 2008, 05:09:53 PM »
Is this it?
« Reply #14 on: June 22, 2008, 05:12:02 PM »
Nope 03F8 is a com port, its a printer port you want to look at.
« Reply #15 on: June 22, 2008, 05:13:05 PM »
I don't know what an xml is. I'm assuming you're asking if the info I'm putting up is from the computer that isn't working with Mach. The answer to that is yes.
« Reply #16 on: June 22, 2008, 05:13:55 PM »
Will do. Keep my name in mindd.
« Reply #17 on: June 22, 2008, 05:16:16 PM »
This should be it.
« Reply #18 on: June 22, 2008, 05:17:44 PM »
lol, your in good company then, talk about blind leading the blind ;)
Ok your old computer had Mach installed and working? If so and you can still access it look in the Mach3 folder on the C drive of it. You will see a file called Mach3Mill.xml (thats presuming its Mill you were using). If you copy that then paste it into your new computers Mach3 folder all your old settings will be as before. The only thing that could be different is the Port address.
« Reply #19 on: June 22, 2008, 05:18:45 PM »
Yes thats oit, standard on board printer port address, 0378.
