Hello Guest it is November 08, 2026, 12:14:53 PM
Author Topic: Changed computers, can't get kboard working. Help!  (Read 137417 times)
Re: Changed computers, can't get kboard working. Help!
« Reply #50 on: June 22, 2008, 07:44:10 PM »
No. I doesn't respond to MDI. It did when this sad tale began a few hours ago. The keyboard wouldn't work but it would respond to commands typed in. However, the DRO does reflect a lift of one inch of the Z even though it never happened. I did hear a stepper thud.
« Reply #51 on: June 22, 2008, 07:46:02 PM »
PS: I did set up the icon on the desktop. And I pasted in the edit.
« Reply #52 on: June 22, 2008, 07:47:04 PM »
Ok, can you check at the breakout board end of the cable, disconnect it and put a voltmeter between the Dir pin of the X axis and one of the ground pins. When you jog one way the meter should be 0v, jog the other and it should change to 5v.
« Reply #53 on: June 22, 2008, 07:49:12 PM »
Gonna look for an image of a cable on Google. If you need to go we can pick it up tomorrow or whnever.
« Reply #54 on: June 22, 2008, 07:51:40 PM »
Here you go
« Reply #55 on: June 22, 2008, 07:52:04 PM »
Does this look right?
« Reply #56 on: June 22, 2008, 07:53:42 PM »
Your just too fast for me. While I get my voltmeter can you tell me which 2 pins?
« Reply #57 on: June 22, 2008, 07:53:54 PM »
Yes but the one in the Mach manual is better ;)
« Reply #58 on: June 22, 2008, 07:55:50 PM »
depends what you have set in your xml, look at your ports and pins, motor setup and you wil see what the Dir pin for X is. any pin from 18 to 25 is the zero volt or ground as I called it (wrongly of course)
« Reply #59 on: June 22, 2008, 07:56:06 PM »
TAking the cable lose won't blow a Gecko will it?
