Hello Guest it is October 05, 2026, 04:07:38 PM
Author Topic: No reverse on homing y  (Read 12719 times)
« on: February 19, 2008, 11:53:38 AM »
My machine has taken to erratic behaviour when homing all axis. z and x ok but sometimes y will back off  the limit switch as it should and other times just stops when it hits the switch and gives  an error message. Where is the routine that controls thiis? Can it be corrected iby an edit  or is it a corruption further back? Thanks, Ralph
Re: No reverse on homing y
« Reply #1 on: February 19, 2008, 12:40:07 PM »
what is the error message?
vmax549
« Reply #2 on: February 19, 2008, 12:49:34 PM »
YOu may have a sloppy switch, try increasing the debounce setting.
« Reply #3 on: February 19, 2008, 01:39:53 PM »
Well, I replaced the switch and it works correctly. If the old one did not produce a sharp, complete break, that could be responsible. Ralph
