Mach Discussion => General Mach Discussion => Topic started by: ktmodelshop on February 19, 2008, 12:53:38 PM
My machine has taken to erratic behaviour when homing all axis. z and x ok but sometimes y will back off the limit switch as it should and other times just stops when it hits the switch and gives an error message. Where is the routine that controls thiis? Can it be corrected iby an edit or is it a corruption further back? Thanks, Ralph
what is the error message?
YOu may have a sloppy switch, try increasing the debounce setting.
Well, I replaced the switch and it works correctly. If the old one did not produce a sharp, complete break, that could be responsible. Ralph
