Hello
Guest
it is
November 01, 2026, 01:01:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
LazyCam (Beta)
LazyCam Pro question
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: LazyCam Pro question (Read 74891 times)
Saumur
79
Re: LazyCam Pro question
Reply #40 on:
March 11, 2008, 01:50:03 PM »
anyone knows if you create a g-code that starts the drawing from the right instead of left?
thanks
Chip
2,055
Gainesville Florida USA
Reply #41 on:
March 11, 2008, 04:00:14 PM »
Hi, Saumur
Move the 0,0 marker to the right side, Click on it hold down and move it to the right side.
Thanks, Chip
Last Edit: March 11, 2008, 04:03:07 PM by Chip
Saumur
79
Reply #42 on:
March 12, 2008, 10:21:28 AM »
Thanks Chip,
one last thing; my drawing is divided in 4 chains.Is there a way to combine them all and have only 1 chain?
I tried with optimize and sometimes it combine 2 chains into 1 but after that i can't combine others 2.
Chip
2,055
Reply #43 on:
March 12, 2008, 12:24:06 PM »
Hi, Saumur
Your lines probillyhave a small gap, Try setting the Setup, Load Options, Connection Line Tol. to .01, then re-load your file.
Thanks, Chip
Last Edit: March 12, 2008, 12:26:06 PM by Chip
Saumur
79
Reply #44 on:
March 13, 2008, 09:45:39 AM »
THANK MAN!!!!
Saumur
79
Reply #45 on:
March 13, 2008, 10:10:48 AM »
Thanks for the help guys thanks to you i learnt many things.
If it's possible to do this i'll be able to do all the things i need: is it possible to create a g0 movement from lazycam so that when the piece is done the tool move away from it?
More like if with lazycam you can create a g0 movement you want or you must do it with your cad?
Saumur
79
Reply #46 on:
March 14, 2008, 10:09:06 AM »
anyone knows?
Overloaded
4,923
Reply #47 on:
March 14, 2008, 11:10:27 AM »
Saumur,
I just edit the tap file at the end.
G0 Z? (to make sure Z is up and will clear everything)
G0 X? Y? (to where ever you want)
M30
Saumur
79
Reply #48 on:
March 14, 2008, 11:21:21 AM »
Thanks for the answer,
yes that's a possibility i just wanted to know if you can create them in LC.
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
