Hello Guest it is November 01, 2026, 01:01:39 PM
Author Topic: LazyCam Pro question  (Read 74892 times)
Re: LazyCam Pro question
« Reply #10 on: March 03, 2008, 08:59:10 AM »
Chip,
yes it a lathe program. Your drawing isn't correct.
Anyway i would like to know why when i create the g-code the tools settings i put don't change the code, it's like they don't get read.
Can you tell me how can i set up my tool?
thanks
« Reply #11 on: March 05, 2008, 08:23:32 AM »
anyone can help me please?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #12 on: March 05, 2008, 05:12:06 PM »
Hi, Saumur
I think you can create them thy will not load though, New LC lathe is in the works, Drought there will be any changes hear.
Thanks, Chip
« Reply #13 on: March 06, 2008, 08:50:38 AM »
so in other words at the moment LC is USELESS for lathe?
« Reply #14 on: March 06, 2008, 11:11:17 AM »
I mean, if i can't set the tool i can't make a correct program. Can i set the tool in Mach3 or what?
If you could help i would really appreciate
« Reply #15 on: March 06, 2008, 01:20:57 PM »
Saumur,
What did you draw the profile with ?  I have old cad and cannot open your dwg and your dxf will not work here.
I made a rough profile similar to yours and Lcam seems to do well with it here.
Is this similar to what it should look like ?
Maybe send your dwg file.
RC
Offline Chip
  •  2,055 2,055
« Reply #16 on: March 06, 2008, 03:23:29 PM »
Hi, RC & Saumur
I had the same problem with the dxf, It loaded weard.
Hears the dxf loaded in rino then bobcad, I think this is correct.
Hope this Helps, Chip
« Reply #17 on: March 06, 2008, 03:44:23 PM »
Hey Chip,
This is what your tap looks like on mine.
Can you put the vertical line for the stock size on the Z+ end and resend the dxf ?
Offline Chip
  •  2,055 2,055
« Reply #18 on: March 06, 2008, 04:19:35 PM »
Hi, RC
You've got Mach set in Diameter Mode, In  Ports & pins, Turn Options.
Hears a dxf ver line z+.
Thanks, Chip
« Last Edit: March 06, 2008, 04:22:16 PM by Chip »
« Reply #19 on: March 06, 2008, 04:35:30 PM »
much MUCH better, I forgot that I went back to dia mode.
The toolpath reduces to very light cuts in the saddle area. Looks like they go to the finish cut increment.
Thanks Chip,
RC
