Hello
Guest
it is
November 01, 2026, 01:01:06 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
LazyCam (Beta)
LazyCam Pro question
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: LazyCam Pro question (Read 74886 times)
Saumur
79
Re: LazyCam Pro question
Reply #10 on:
March 03, 2008, 08:59:10 AM »
Chip,
yes it a lathe program. Your drawing isn't correct.
Anyway i would like to know why when i create the g-code the tools settings i put don't change the code, it's like they don't get read.
Can you tell me how can i set up my tool?
thanks
Saumur
79
Reply #11 on:
March 05, 2008, 08:23:32 AM »
anyone can help me please?
Chip
2,055
Gainesville Florida USA
Reply #12 on:
March 05, 2008, 05:12:06 PM »
Hi, Saumur
I think you can create them thy will not load though, New LC lathe is in the works, Drought there will be any changes hear.
Thanks, Chip
Saumur
79
Reply #13 on:
March 06, 2008, 08:50:38 AM »
so in other words at the moment LC is USELESS for lathe?
Saumur
79
Reply #14 on:
March 06, 2008, 11:11:17 AM »
I mean, if i can't set the tool i can't make a correct program. Can i set the tool in Mach3 or what?
If you could help i would really appreciate
Overloaded
4,923
Reply #15 on:
March 06, 2008, 01:20:57 PM »
Saumur,
What did you draw the profile with ? I have old cad and cannot open your dwg and your dxf will not work here.
I made a rough profile similar to yours and Lcam seems to do well with it here.
Is this similar to what it should look like ?
Maybe send your dwg file.
RC
Chip
2,055
Reply #16 on:
March 06, 2008, 03:23:29 PM »
Hi, RC & Saumur
I had the same problem with the dxf, It loaded weard.
Hears the dxf loaded in rino then bobcad, I think this is correct.
Hope this Helps, Chip
Overloaded
4,923
Reply #17 on:
March 06, 2008, 03:44:23 PM »
Hey Chip,
This is what your tap looks like on mine.
Can you put the vertical line for the stock size on the Z+ end and resend the dxf ?
Chip
2,055
Reply #18 on:
March 06, 2008, 04:19:35 PM »
Hi, RC
You've got Mach set in Diameter Mode, In Ports & pins, Turn Options.
Hears a dxf ver line z+.
Thanks, Chip
Last Edit: March 06, 2008, 04:22:16 PM by Chip
Overloaded
4,923
Reply #19 on:
March 06, 2008, 04:35:30 PM »
much MUCH better, I forgot that I went back to dia mode.
The toolpath reduces to very light cuts in the saddle area. Looks like they go to the finish cut increment.
Thanks Chip,
RC
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
