Hello
Guest
it is
November 23, 2026, 03:03:50 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Discontinuous execution of the contours
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Discontinuous execution of the contours (Read 14576 times)
giordano
56
on:
April 27, 2006, 07:29:36 AM »
Hi to all. Since I had any losses of step, I have reduced the acceleration of the 10-20s motors mm s/s. As in the figure.
In this way the execution of a circle is not uniform anymore, but to hiccup. There is a cure. Thanks in advance, Giordano
Logged
Brian Barker
3,860
Re: Discontinuous execution of the contours
Reply #1 on:
April 28, 2006, 07:18:54 AM »
You have to Retune your axis after you change your Khz mode. Sorry
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
