Hello Guest it is November 22, 2026, 08:09:14 AM
Author Topic: How to post code in Write wizard?  (Read 19662 times)
« on: January 19, 2008, 02:12:37 PM »
There seems to be no 'post code and exit' button in the 'Write' wizard screen.
So how do I get the code after I have entered then text and parameters?
Richard
Re: How to post code in Write wizard?
« Reply #1 on: January 19, 2008, 03:57:31 PM »
Richard,
I just hit the Write button and wait a second and it posts the code.
RC
At times, click write.. then click return to Mach3.
« Last Edit: January 19, 2008, 10:20:40 PM by Overloaded »
« Reply #2 on: January 20, 2008, 02:23:50 PM »
Richard,
RC
Thanks for that, I tried it but nothing happens. I tried a few other wizards, they all seem to work OK.
I must be missing something. I REALLY WISH there were simple help files for these things!
Richard
« Reply #3 on: January 20, 2008, 03:59:02 PM »
Strange................Works here every time.
RC
« Reply #4 on: January 20, 2008, 04:48:38 PM »
Try hitting the Enter(return) Key on your keyboard, it should work with the on screen one though.
« Reply #5 on: January 20, 2008, 05:16:28 PM »
Hood,
Could this reqiure the lic. file ?
Richard,
Do you have the lic.?
« Reply #6 on: January 20, 2008, 05:25:26 PM »
Shouldnt do as its just a Mach wizard written by German Bravo (I think) and not one of the NewFangled addons that require a seperate licence.
  •  9,378 9,378
« Reply #7 on: April 04, 2009, 07:12:23 AM »
Something  that is easily overlooked when using the Write Wizard for the first time on a new installation of Mach is to click on one of the direction buttons. If you don't then the only GCode you get on the Mach screen consists of Z moves only, everything else is 0.0000.
« Reply #8 on: April 04, 2009, 07:31:31 AM »
You have to make sure that EVERY option is selected, or the Write wizard won't work. Carefully go over the entire screen and make sure you don't miss anything.
  •  9,378 9,378
« Reply #9 on: April 05, 2009, 06:05:05 AM »
