Hello Guest it is November 13, 2026, 11:07:22 AM
Author Topic: File Association ?  (Read 24855 times)
File Association ?
« on: November 18, 2007, 04:54:31 PM »
When attempting to download attachments from the posts, I get a "Windows File Association... Unknown File Type".
I went to "Folder Options" but am unclear as to what to do from there.
Can anyone help ?
(my 1st PC)
Re: File Association ?
« Reply #1 on: November 18, 2007, 04:57:03 PM »
what is the extension?
« Reply #2 on: November 18, 2007, 05:02:58 PM »
.set
In folder options, .set is with Screen 4
« Reply #3 on: November 18, 2007, 05:03:25 PM »
Oops just noticed you are new to PCs so if you dont know what I am meaning when I said the extension, it is the  letters after the . (dot) that we need to know ie Mach3.xml (file extension is xml)  or Screen4.exe (file extension is exe)
« Reply #4 on: November 18, 2007, 05:05:35 PM »
ok you just need to open it either in Mach by going to the view tab then load screens and browse to the file you downloaded or you can go to Mach3 folder and open Screen4.exe and browse to the file you downloaded.
« Reply #5 on: November 18, 2007, 06:11:49 PM »
OKEE DOKEE, that works.
But... it's a Profile Shapes Wizard and it looks like I cannot open it without the license. (coming soon)
Thanks Hood
« Reply #6 on: November 19, 2007, 01:06:32 AM »
If its a wizard then place it in the C:\Mach3\Addons folder and you should then be able to start Mach3 and see it by going to the wizards tab.
« Reply #7 on: November 19, 2007, 06:31:46 AM »
Hood,
It's in the add-on folder but not in any of the Mach Wizard tabs.
When I try to open the file from the folder, I get a small pop-up window:
                      Mach4                                                   X
                      Corrupt install, no license file found. Aborting
Then the agreement window, which is blank.
Then a Mach screen that is also blank.
I guess I need the license file.
« Reply #8 on: November 19, 2007, 10:17:37 AM »
can you give me a link to where you downloaded it?
