Hello Guest it is November 13, 2026, 02:53:02 PM
Author Topic: File Association ?  (Read 24879 times)
Re: File Association ?
« Reply #10 on: November 19, 2007, 11:12:15 AM »
Thanks, I just downloaded and unzipped it to C:\Mach3\Addons
When you go to the addons folder you should now see a folder called Profile Shapes and within that folder there should be 2 files, one called Profile Shape Wizard.set and the other Profile Shape Wizard.set.def.
You should then be able to open the wizard from Mach.
If you still cant let me know and I will remove my license and see what happens here.
« Reply #11 on: November 19, 2007, 11:23:19 AM »
Yep..same here.
The files are there but when I try to open them I get the "Abort" pop-up mentioned earlier.
I plan to get the license this week. If you don't mind, try it with your license off, just curious.
« Reply #12 on: November 19, 2007, 11:33:50 AM »
Works fine for me with when I remove the license, maybe you should try downloading it  and unzipping it again.
« Reply #13 on: November 19, 2007, 11:51:32 AM »
Did...3 times...all the same.
"Corrupt install, no license file found. Aborting"
That's what I get every time.
No biggie, I'll see what happens after I'm licensed.
Maybe your system still sees your license even though you removed it.
Thanks Hood
« Reply #14 on: November 19, 2007, 12:56:51 PM »
Nope, its definitely not seeing my license as I looked and it shows it as an unlicensed copy.
Hope it works when you get a license but if not then let me know and I will try and find out why.
