Hello Guest it is October 25, 2026, 02:36:15 AM
Author Topic: Probe calibration error  (Read 27911 times)
« on: June 13, 2021, 12:48:47 AM »
I have the latest ESS plugin and Mach4 version and I'm trying to calibrate a probe.
I've filled out the probe settings page and have moved onto calibration.
When trying to calibrate x and y with a gauge ring the result is the machine moving into x and y zero, Z to probing height (-3), but then gives me a "Probing Error" followed by disabling Mach4
My history says,
ESS starting Probe 0
ESS: Failure! Probe0 never hit or the allowed distance was traveled. Switching from PROBING to NORMAL state.
ERROR: No contact with probe
This is as far as I've got. Has anyone struck this before, I'm not sure what to do to fix it.
Re: Probe calibration error
« Reply #1 on: June 13, 2021, 04:05:49 AM »
G31 x10 f25 in the MDI works as I assume it should. (Same for Y and Z).
Is it necessary to calibrate the probe? Can I just fill in the touch off parameters (under the touch button) and go?
« Reply #2 on: June 13, 2021, 05:53:02 AM »
Been playing around in the "Touch off UI" and it works like it should when using the single side touch functions but when I try to use the corner functions it will touch Z, move up Z, then out in Y to where it should drop down in Z but stops instead. A few seconds go by and the same error pops up again.
ERROR: No contact with probe.
It's almost like there's to much data for it to process so it faults?
« Reply #3 on: June 19, 2021, 10:10:16 PM »
No one has come across this huh? Must be something in the computer.
« Reply #4 on: September 03, 2021, 07:56:45 AM »
Did you ever sort this out. I am having the same issue.
Offline nc42
  •  20 20
« Reply #5 on: September 03, 2021, 11:24:55 AM »
I'm trying to calibrate my probe and I'm getting the same problem for xy calibration or radius calibration. I can run a normal bore probe cycle just fine. Same problems and history as the original poster
« Reply #6 on: September 03, 2021, 05:15:06 PM »
No resolve on this yet. I don't know if it's software related or hardware that's causing the issue. Haven't had much time to work on it ether. I've been working around the issue by manually probing.
« Reply #7 on: September 03, 2021, 08:51:46 PM »
Hello.
Please look at the photo. I got a similar error.
And I've already been featured in this forum.
It will be Reply # 12.
https://www.machsupport.com/forum/index.php?topic=45209.10
In my case, probe was an experiment with a manual switch.
Therefore, I thought that I could only experiment with a real milling machine. Also, I thought that the script was not made like a manual switch.
Probing Calibration Mach4 step 1
https://www.youtube.com/watch?v=9LvV6iC3zmY
postscript
If you touch the probe before Z reaches the inspection point, it behaves like a video.
« Last Edit: September 03, 2021, 09:03:14 PM by Toshio.K »
« Reply #8 on: September 03, 2021, 11:26:02 PM »
Mr.gyrojeremy.
Hello.
After all, it was causing the same phenomenon as I was.
I am also a DIY probe.
When touched, the current flows to GND.
Wouldn't these things get angry with a real Probe?
When I watch the video, I wonder why it's different from me.
« Last Edit: September 03, 2021, 11:28:35 PM by Toshio.K »
Offline nc42
  •  20 20
« Reply #9 on: September 06, 2021, 08:34:35 AM »
Does anyone know of a way to manually enter the radius calibration number?
