Hello Guest it is October 17, 2026, 07:16:16 AM
Author Topic: Mach3  (Read 21526 times)
Mach3
« on: May 06, 2021, 08:03:03 AM »
Mach 3
Hi there...I've been looking for the correct port address to use for my USB controller....all the blogs I read mention the printer port address but I cannot find anything on USB settings.
Can any helps please?
Iain
Offline TPS
  •  2,627 2,627
Re: Mach3
« Reply #1 on: May 06, 2021, 11:56:46 AM »
usb Controller will Need a plugin.
Re: Mach3
« Reply #2 on: May 07, 2021, 01:21:26 AM »
So you don’t enter any settings for the port number if it’s usb?  The driver takes care of the address?  Cheers Iain
Offline TPS
  •  2,627 2,627
Re: Mach3
« Reply #3 on: May 07, 2021, 01:45:54 AM »
there is no "global" answer for this, it is allways depending on your Controller.
witch Controller are you using?
any documentation avaliable?
Re: Mach3
« Reply #4 on: May 09, 2021, 05:04:40 AM »
No, no port address needed with a USB controller.
