Hello Guest it is September 28, 2026, 07:15:39 PM
Author Topic: X axis direction  (Read 15264 times)
Offline onescentpro
  •  6 6
  • Newbie
X axis direction
« on: April 14, 2021, 11:43:56 AM »
Does anyone have an idea why when I jog the X axis with the x- and x+ that they move in the same direction? Has anyone had that problem and if so, how do you fix it?
Offline TPS
  •  2,627 2,627
Re: X axis direction
« Reply #1 on: April 14, 2021, 12:24:37 PM »
possible Problems:
-Dir Signal wrong configured
-Dir Signal wrong wiring
-System >Hotkey's same keycode for both direction's
Offline onescentpro
  •  6 6
  • Newbie
« Reply #2 on: April 15, 2021, 10:53:47 AM »
Thanks, got it working.
« Reply #3 on: June 26, 2021, 09:28:48 PM »
Can you tell me exactly what you did?   I am having this exact problem with my Y and slaved A motors....they start out working fine, and then both the + and - jog send it the same direction...which is incidentally the direction that it is running very smoothly....the other direction is very jerky and struggling.
