Mach Discussion => FAQs => Topic started by: onescentpro on April 14, 2021, 12:43:56 PM
Does anyone have an idea why when I jog the X axis with the x- and x+ that they move in the same direction? Has anyone had that problem and if so, how do you fix it?
possible Problems:
-Dir Signal wrong configured
-Dir Signal wrong wiring
-System >Hotkey's same keycode for both direction's
Thanks, got it working.
Can you tell me exactly what you did? I am having this exact problem with my Y and slaved A motors....they start out working fine, and then both the + and - jog send it the same direction...which is incidentally the direction that it is running very smoothly....the other direction is very jerky and struggling.
