Hello Guest it is October 24, 2026, 06:23:42 PM
Author Topic: X and Y axis homing in the wrong direction  (Read 8102 times)
« on: December 09, 2020, 11:06:27 AM »
My X axis switch is on the far left as facing the machine, and my Y axis switch is at the front.  So I want them to home in the negative direction for the axis.
The Z axis switch is the opposite.  I have it set so it stops the spindle from going too high, thus the positive direction.
The Z axis homes properly for what I want, but the X and Y go the opposite direction that I want them too, that is, also in the positive like the Z axis.
How do I make my X and Y home in the negative direction, that is, to the left?
Re: X and Y axis homing in the wrong direction
« Reply #1 on: December 09, 2020, 11:59:09 AM »
I forgot to mention.  I use as ESS.
« Reply #2 on: December 09, 2020, 01:05:30 PM »
You can set the homing direction in the 'Homing/SoftLimits' tab in the Control Configuration. It is the first column
« Reply #3 on: December 09, 2020, 01:21:14 PM »
Thank you!  I must be blind.
