Hello
Guest
it is
October 21, 2026, 12:33:35 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Radius to end of arc differs from start
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Radius to end of arc differs from start (Read 19116 times)
Wattsy
6
Re: Radius to end of arc differs from start
Reply #10 on:
November 19, 2020, 12:11:12 PM »
Does anyone know how I can fix the problem in Mach 3 ??
TPS
2,627
Reply #11 on:
November 19, 2020, 01:14:04 PM »
pls post your "Profile".xml file
Graham Waterworth
2,785
Yorkshire Dales, England
Reply #12 on:
November 20, 2020, 02:21:04 PM »
The code I posted was in Diameter mode so if you change Mach to diameter mode all should look good.
Are you using Radius mode for any special reason, most lathes are programmed Diameter.
Print
Pages:
1
2
Go Up
« previous
next »
