Hello Guest it is October 03, 2026, 03:42:25 PM
Author Topic: Copycat plugin to "teach" more than 3 axis possible ?  (Read 10355 times)
« on: October 04, 2020, 11:36:31 AM »
hello dear forum,
for an application I need to "teach in" koordinates of 5 axis into G-code file
however copy cat plugin teaches ony 3 axis ?
what can I do ?
thank you
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Copycat plugin to "teach" more than 3 axis possible ?
« Reply #1 on: October 04, 2020, 05:04:47 PM »
You can load the copycat screen and remove the Rem( ' ) out of each buttons VB code for A & B axis.
« Reply #2 on: October 05, 2020, 02:56:29 PM »
hello thank you - where can I find the VB script for copycat ?
« Reply #3 on: October 07, 2020, 12:30:21 PM »
I still need help about this problem - thank you
  •  9,374 9,374
« Reply #4 on: October 08, 2020, 12:26:38 AM »
The Mach3 Copycat wizard only supports 3 axis.
Offline TPS
  •  2,627 2,627
« Reply #5 on: October 08, 2020, 01:48:04 AM »
as Graham said, use a screeneditor like Machscreen, open the Copycat screenset (C:\mach3\addons\copycat\copycat.set)
and edit the code of the button's where cou need 5 axis.
