Mach Discussion => General Mach Discussion => Topic started by: magnetron on October 04, 2020, 12:36:31 PM
hello dear forum,
for an application I need to "teach in" koordinates of 5 axis into G-code file
however copy cat plugin teaches ony 3 axis ?
what can I do ?
thank you
You can load the copycat screen and remove the Rem( ' ) out of each buttons VB code for A & B axis.
hello thank you - where can I find the VB script for copycat ?
I still need help about this problem - thank you
The Mach3 Copycat wizard only supports 3 axis.
as Graham said, use a screeneditor like Machscreen, open the Copycat screenset (C:\mach3\addons\copycat\copycat.set)
and edit the code of the button's where cou need 5 axis.
