Hello Guest it is November 23, 2026, 05:06:33 AM
Author Topic: not getting any spindle read out from photo interrupter  (Read 18061 times)
« on: March 26, 2020, 06:56:17 PM »
I am running the current version of Mach3 on XP 32 bit and ,using a photo interrupter on single slotted disc pick up,
I cannot see any movement on the spindle DRO.  What am I doing wrong.
Ps. The electronics have been checked to the end of the parallel port extension lead and all appear to be OK.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: not getting any spindle read out from photo interrupter
« Reply #1 on: March 26, 2020, 07:18:51 PM »
You need to have the input port and pins set for index and then set the index de-bounce to 0 or 1 in the general config screen.
Can you see the index LED flash in the diagnostics screen if you turn the spindle by hand?
« Last Edit: March 26, 2020, 07:20:50 PM by Graham Waterworth »
« Reply #2 on: March 26, 2020, 08:08:40 PM »
Thanks for the rapid reply. No I don't see the LED flash when I rotate the chuck manually. I am currently making enquiries with Artsoft about the currency of my licence as it may have disappeared with a deceased older computer, although a hard drive transplant was attempted.
Anyhow I am currently waiting for a reply about this.
Thanks again ,
Mike Patterson
