Hello Guest it is October 30, 2026, 03:40:27 PM
Author Topic: Plugin that works for Chinese mpg pendant  (Read 89636 times)
Re: Plugin that works for Chinese mpg pendant
« Reply #10 on: January 17, 2020, 05:37:30 PM »
Here is what came with the mpg pendant
« Last Edit: January 18, 2020, 01:36:11 AM by Tweakie.CNC »
Cadcam Man
  •  9,375 9,375
« Reply #11 on: January 18, 2020, 01:41:33 AM »
Hi Cad cam man,
It would be helpful for easy viewing if you would resize your pictures to 800 x 600 before posting. This thread refers; https://www.machsupport.com/forum/index.php?topic=24585.0
Many thanks,
Offline TPS
  •  2,627 2,627
« Reply #12 on: January 18, 2020, 02:04:25 AM »
according to the example from my link wiring would be:
yellow -> Pin 3
yellow/black -> Pin 4
Brown -> Pin 5
Brown/black -> Pin 6
gray -> Pin 7
gray/black -> Pin 8
orange -> Pin 9
orange/black -> Pin 25
green -> Pin 13
White -> Pin 15
red -> Pin 10
black - Pin 24
the you can use all Settings from example
« Reply #13 on: January 18, 2020, 09:38:09 AM »
@tweakie sorry I didnt know there was a preference of size picture to post .. I will be sure to resize them in the future...
@ tps.. so are you saying I should rewire my whole pendant to match the example you posted ?? The wire color does not matter as long as I know what colors go where and they all match up according to the example in reply #10
Cadcam Man
Offline TPS
  •  2,627 2,627
« Reply #14 on: January 18, 2020, 12:07:14 PM »
for the Moment i am not able to follow you, how the pedant is wired on the PP port side??!
« Reply #15 on: January 18, 2020, 02:52:31 PM »
Sorry for the confusion I have the pendant wired just like the instructions that came with it as.
Red - +5v( outside source )
Black - gnd ( outside source)
Green- 2 pin ( mpg A+)
White- 3 pin ( mpg B+ )
Green&black- 1 pin ( jog on led +5v )
White&black- gnd ( jog on led gnd)
Yellow- 4 pin ( select x axis )
Yellow&black- 5 pin ( select y axis )
Brown- 6 pin ( select z axis )
Brown&black- 7pin ( select a axis )
Gray- 8pin ( x1 )
Gray&black- 9pin ( x10 )
Orange- 10pin ( x100 )
Orange&black- +5v ( com for selector )
All the other color and number not listed above are not being used and have nothing connected to them
I hope this clears it up for you
Cadcam Man
Offline ZASto
  •  434 434
« Reply #16 on: January 18, 2020, 03:16:18 PM »
GND from outside source and GND of your Parallel port should be connected or your encoder outputs will be referenced to what?
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
Offline TPS
  •  2,627 2,627
« Reply #17 on: January 19, 2020, 02:57:31 AM »
Config -> Ports&Pins -> Encoder/MPS -> MPG1 Enabled | A-Port = 2 | A-Pin = 2 | B-Port = 2 | B-Pin = 3
this is only the led, we will take care later
Config -> Ports&Pins -> Input Signal -> OEMTrigger#1 Enabled | Port = 2 | Pin = 4
System Hotkeys -> Trigger#1 OEM Code = 259
Config -> Ports&Pins -> Input Signal -> OEMTrigger#2 Enabled | Port = 2 | Pin = 5
System Hotkeys -> Trigger#1 OEM Code = 260
Config -> Ports&Pins -> Input Signal -> OEMTrigger#1 Enabled | Port = 2 | Pin = 6
System Hotkeys -> Trigger#1 OEM Code = 261
Config -> Ports&Pins -> Input Signal -> OEMTrigger#1 Enabled | Port = 2 | Pin = 7
System Hotkeys -> Trigger#1 OEM Code = 262
Gray- 8pin ( x1 )
Config -> Ports&Pins -> Input Signal -> OEMTrigger#1 Enabled | Port = 2 | Pin = 8
System Hotkeys -> Trigger#1 OEM Code = 265
Config -> Ports&Pins -> Input Signal -> OEMTrigger#1 Enabled | Port = 2 | Pin = 9
System Hotkeys -> Trigger#1 OEM Code = 266
Config -> Ports&Pins -> Input Signal -> OEMTrigger#1 Enabled | Port = 2 | Pin = 10
System Hotkeys -> Trigger#1 OEM Code = 267
this is wrong, Needs to be connected to GND
Offline TPS
  •  2,627 2,627
« Reply #18 on: January 19, 2020, 03:19:32 AM »
and as ZASTo sayed
GND from outside source and GND of your Parallel port should be connected pin 18-25
Offline ZASto
  •  434 434
« Reply #19 on: January 19, 2020, 04:08:33 AM »
TPS, you "messed up" a bit :)
        Personal Message (Offline)
« Reply #17 on: 19-01-2020, 10:57:31 »
Gray- 8pin ( x1 )
Same OEMTrigger on different pins :D
I know, it is a Copy/Paste common error :D :D :D
