Hello Guest it is October 30, 2026, 03:02:44 PM
Author Topic: Plugin that works for Chinese mpg pendant  (Read 89632 times)
Offline TPS
  •  2,627 2,627
Re: Plugin that works for Chinese mpg pendant
« Reply #20 on: January 19, 2020, 06:50:05 AM »
ok corrected Version
Green- 2 pin ( mpg A+)
White- 3 pin ( mpg B+ )
Config -> Ports&Pins -> Encoder/MPS -> MPG1 Enabled | A-Port = 2 | A-Pin = 2 | B-Port = 2 | B-Pin = 3
Green&black- 1 pin ( jog on led +5v )
White&black- gnd ( jog on led gnd)
 this is only the led, we will take care later
Yellow- 4 pin ( select x axis )
Config -> Ports&Pins -> Input Signal -> OEMTrigger#1 Enabled | Port = 2 | Pin = 4
System Hotkeys -> Trigger#1 OEM Code = 259
Yellow&black- 5 pin ( select y axis )
Config -> Ports&Pins -> Input Signal -> OEMTrigger#2 Enabled | Port = 2 | Pin = 5
System Hotkeys -> Trigger#2 OEM Code = 260
Brown- 6 pin ( select z axis )
Config -> Ports&Pins -> Input Signal -> OEMTrigger#3 Enabled | Port = 2 | Pin = 6
System Hotkeys -> Trigger#3 OEM Code = 261
Brown&black- 7pin ( select a axis )
 Config -> Ports&Pins -> Input Signal -> OEMTrigger#4 Enabled | Port = 2 | Pin = 7
System Hotkeys -> Trigger#4 OEM Code = 262
Gray- 8pin ( x1 )
 Config -> Ports&Pins -> Input Signal -> OEMTrigger#5 Enabled | Port = 2 | Pin = 8
System Hotkeys -> Trigger#5 OEM Code = 265
Gray&black- 9pin ( x10 )
 Config -> Ports&Pins -> Input Signal -> OEMTrigger#6 Enabled | Port = 2 | Pin = 9
System Hotkeys -> Trigger#6 OEM Code = 266
Orange- 10pin ( x100 )
Config -> Ports&Pins -> Input Signal -> OEMTrigger#7 Enabled | Port = 2 | Pin = 10
System Hotkeys -> Trigger#7 OEM Code = 267
Orange&black- +5v ( com for selector )
this is wrong, Needs to be connected to GND
« Last Edit: January 19, 2020, 06:52:18 AM by TPS »
« Reply #21 on: January 19, 2020, 09:18:18 AM »
So how do I check to see if the orange black should be gnd???
Cadcam Man
Offline TPS
  •  2,627 2,627
« Reply #22 on: January 19, 2020, 10:26:05 AM »
orange/black is the com of all Switches, and for switching Inputs at a parallel port they Need to be taken to gnd.
Offline ZASto
  •  434 434
« Reply #23 on: January 19, 2020, 01:24:16 PM »
In the attached archive is settings with brains that work on my computer.
Due to the parts that I had "on hand" OemTrigger#7 is actually a switch on low cost encoder that is used to switch Jogging On/Off.
My personality is who I am.
« Reply #24 on: January 19, 2020, 02:36:05 PM »
Cool thanks Zasto so all I enable all brn. Files and it should work??do u agree with the orange and black ( com  wire ) should be ground?
Cadcam Man
Offline ZASto
  •  434 434
« Reply #25 on: January 19, 2020, 02:48:58 PM »
Those 2 .brn files you can copy to Autoload folder and they will be by default enabled.
ALL wires that are referenced as 0V/COM should be connected to GND pin of parallel port (pins 18..25)
L+ to pin1 of parallel port, L- to GND
LED will be lit when LED on screen whch indicates Jog ON is lit.
So:
Yellow to pin4
Yellow/Black to pin5
Brown to pin6
Gray to pin8
Gray/Black to pin9
Orange to pin10
L+ to pin1
Orange/Black + L- to pin25
You could also reconfigure ESTOP to be on LPT2 then:
Blue to ESTOP pin
Blue/Black to pin25
« Reply #26 on: January 20, 2020, 09:02:44 AM »
I had the orange and black wire that was labeled ( com ) going to +5v and was getting some results but the axis selector and the resolution switches were not selecting the right function. I changed the com wire to gnd like you said in the post above and got nothing ...no results at all ...so I went back to com to +5v and now the switches work but I can not get them to work right ...meaning when I select the x axis it will select it or when I select the x100 it will select it . Right now when i try to select an axis or a resolution the lights change on the diagnostic page but the jog flyout does not change
Cadcam Man
Offline ZASto
  •  434 434
« Reply #27 on: January 20, 2020, 09:48:39 AM »
Well, you will force me to make a video :(
Common wire for selector switches should be connected to LPT GND.
OEMTriggers should be LOW Active as LPT port is providing current for sensing which pin is grounded
Offline TPS
  •  2,627 2,627
« Reply #28 on: January 20, 2020, 10:43:58 AM »
small question, witch light Change on diagnostic Screen?
you are using ZASto's Brains now, all Trigger' oemcodes set to -1 in Config System hotkeys?
all plugin's  related to any mpg deleted from plugin Folder?
pls post your Profile XML.
« Reply #29 on: January 22, 2020, 12:51:28 PM »
update on mpg: Ok after alot of chasing the wires and matching them with the pins they go with I finally got it to work, Thanks to the one and only ZASto!!!!!! All the help from tps and Zasto I was able to finally get the mpg to finally work well done guys I thank the both of you for all the help now I can finally get the project I was working on before I got side tracked by this mpg deal any way the problem was the wires I was using and the pin numbers were not the same for some reason in windows the pin number and the wire were not synced . I was able to use the c22 bob to check what pin was active then changing it in Mach3 to make them both the same I think this is a Windows Xp issue when dealing with the pci card addon lpt2 port and the version of xp I have so any way that was what it was and Im up and running
Cadcam Man
