Hello Guest it is October 30, 2026, 11:59:47 AM
Author Topic: Plugin that works for Chinese mpg pendant  (Read 89599 times)
« on: January 15, 2020, 08:12:34 AM »
Hello guys,
I recently purchased a mpg pendant from ebay it is the typical 4 axis jog pendant wired it does not have an enable button or a e stop all it has is the axis selector and x,y,z,a selector and the dial encoder. I have tried using every plugin , brain that I could find and nothing works . I have a hp a1140n desktop running windows xp pro with the 3.066 version of mach3 . I added a 2nd printer port and a c22 board . The problem is when mapped the keys/functions mach3 acts like it does not see the change so am I missing something or doing something wrong . Like I said I have tried every thing I can think of I have even went back and had all my wiring checked by someone else for a fresh set of eyes and it all looks right . Does anyone have any ideas on what I can do to gain control of my axis selection and my resolution selection
Cadcam Man
Offline TPS
  •  2,627 2,627
Re: Plugin that works for Chinese mpg pendant
« Reply #1 on: January 15, 2020, 08:19:45 AM »
if it is hardwired to lpt2 you will not Need any plugin at all.
here:
http://www.markusmechatronics.com/Handrad_HowTo.html
is an example for a hardwired pedant.
« Reply #2 on: January 16, 2020, 09:39:38 AM »
here:
The pendent I am using is a little different than the one in this setup
1) I dont have a enable button on the side of my pendent.
2) The pendent I am using does not have an e-stop  button on it
I dont know if these differences will matter i have a c22 board but i can also plug the pendent directly into the pc as well
Cadcam Man
Offline TPS
  •  2,627 2,627
« Reply #3 on: January 16, 2020, 11:11:42 AM »
does not matter just skip them, the pricipal is the same.
« Reply #4 on: January 16, 2020, 04:46:17 PM »
Pics
Cadcam Man
« Reply #5 on: January 16, 2020, 04:46:58 PM »
Pics
Cadcam Man
« Reply #6 on: January 16, 2020, 04:47:35 PM »
Pic
Cadcam Man
« Reply #7 on: January 16, 2020, 04:48:17 PM »
Dial
Cadcam Man
Offline TPS
  •  2,627 2,627
« Reply #8 on: January 17, 2020, 09:25:46 AM »
is there no documentation about the used wire color's?
« Reply #9 on: January 17, 2020, 11:58:19 AM »
Yes there is Chinenglish but the colors were all I needed and all the wires r all wires correctly I will post a pic of the instructions when I get off work I get off at 4 central time usa
Cadcam Man
