Hello Guest it is November 13, 2026, 10:47:18 AM
Author Topic: Go to Zero extremely slow, please help  (Read 38865 times)
« on: September 10, 2019, 01:10:41 PM »
I am new to this forum and really hope someone can help me with the following problem:
I recently bought a cnc plasmatable. Everything worked as it should in 'dry runs' (without the plasma turning on). As I discovered my old plasma source had HF ignition really caused problems with the cnc system. On ignition the conection with the Xulifeng motion Card was lost everytime.  I tried to improve earthing (is this the right term?) but in the end I had to buy a source without HF.
After installing the new source almost everything works as it should. When I run a G-code or use the arrow keys the machine works at normal speeds. If I use the 'go to zero' button however the machine moves extremely slow. Almost invisible movement. I tried to change settings but ran out of ideas.
Could the HF ignition have damaged the hardware? That seems unlogic or strange because the speeds are normal with keys and G-codes? If not damaged, does anyone have an idea how to solve it?
Kind regards
« Last Edit: September 10, 2019, 01:15:56 PM by Hanjelle »
Re: Go to Zero extremely slow, please help
« Reply #1 on: September 10, 2019, 02:00:55 PM »
when Mach starts it defaults to a low 6% of max speed.
You can change that by including an F********* word in the initialization string that runs at startup.
« Reply #2 on: September 10, 2019, 02:22:01 PM »
Hi Graig, thank you very much. I tried this option already by including F1000 in the initialzation string. Didn't do a thing unfortunately. I restarted several times but no luck!
« Reply #3 on: September 13, 2019, 02:37:25 AM »
Is it possible that the problem is caused by soft limits? My machine does not have physical home switches but worked fine a month ago. Maybe I accidentelly changed setting or something. My table is 2x1 meter. Actual settings in home/soft limits are:
X: no reversed, Soft max 2000, soft min -100, slow zone 1.00, home off 0.000, no home neg, auto zero, speed 100
Y: same but soft max 1000
Everytime I startup the machine I position the machine at the right place and zero X, Y and also the machine coordinates.
Offline ZASto
  •  434 434
« Reply #4 on: September 13, 2019, 03:48:13 AM »
If your machine have no home switches then soft limits are inoperative.
My personality is who I am.
« Reply #5 on: September 13, 2019, 03:54:05 AM »
@ZASto
Okay, so that can't be the problem? I was assuming that without the physical switches te machine would use the 'ref all home' zero point as a reference to zero end the soft limits would work with that.
Do you have any other idea what the cause of my problem can be?
« Reply #6 on: September 13, 2019, 06:46:02 AM »
  I was assuming that without the physical switches the machine would use the 'ref all home' zero point as a reference to zero end the soft limits would work with that.
You are correct, that is how mine works.
Not sure tho about your speed issue.
Are you running a legal licensed version ?
« Reply #7 on: September 13, 2019, 06:47:24 AM »
Yes, i do have a legal license. So that can't be the problem i think
« Reply #8 on: September 13, 2019, 06:51:53 AM »
Rename and post your XML file and I will try to replicate the problem here.
« Reply #9 on: September 13, 2019, 06:54:32 AM »
thank you! I will post it in a few moments
