Hello Guest it is October 30, 2026, 03:42:24 PM
Author Topic: Go to Zero extremely slow, please help  (Read 38298 times)
Re: Go to Zero extremely slow, please help
« Reply #20 on: September 13, 2019, 03:23:46 PM »
yes that is normal, the homing speed is set in the Homing/Limits page.
« Reply #21 on: September 13, 2019, 03:49:54 PM »
Thanks Graig, so after changing the reference point the machine has to make slow passes to learn. After teaching is runs normal
« Reply #22 on: September 13, 2019, 07:19:11 PM »
According to your XML, your homing speeds are far faster than a creep.
Should not be :
"If I use the 'go to zero' button however the machine moves extremely slow. Almost invisible movement".  (from your first post)
« Last Edit: September 13, 2019, 07:21:51 PM by Overloaded »
« Reply #23 on: September 13, 2019, 07:28:46 PM »
when Mach starts it defaults to a low 6% of max speed.
.... actually, it defaults to 6.00 units per min.
Inches would be quite "visible", but mm's would barely creep.
Increase override 200% and that DRO goes to 12  :)
What is showing in the attached pic while your machine is invisibly moving after hitting the "Go to Zero" button ?
The set feedrate is 1000
Units/min runs between 9000 and 10000
Units/rev is 0
So, this is showing while the machine is going to zero after the button press ? ? ? and  ...
 "If I use the 'go to zero' button however the machine moves extremely slow. Almost invisible movement."
I'm at a loss here. Not sure what is going on .
 :o
« Reply #24 on: September 14, 2019, 12:55:21 AM »
Should not be :
Isn't it possible mach3 or my controller has a build in safety feature? After changing settings fist a slow run?
Maybe it's hardwarerelated after all. But it's working now. I will monitor it for some time and report conclusions here
« Reply #25 on: September 14, 2019, 12:58:02 AM »
Units/rev is 0
 :o
Haha, I can imagine that! You should see my face during the whole proces. I am definetely not the expert here but I am also really confused. It does not make sense at all. As mentioned in the previous post I will monitor it for some time
Everybody: thanks for your input so far!!
