Hello Guest it is October 31, 2026, 06:22:21 PM
Author Topic: Go to Zero extremely slow, please help  (Read 38368 times)
Re: Go to Zero extremely slow, please help
« Reply #10 on: September 13, 2019, 07:01:35 AM »
This is the xml.file. I copied it without renaming it. Really curious if you find something! Many thanks in advance
« Reply #11 on: September 13, 2019, 07:18:29 AM »
I had to rename it otherwise it would not upload
« Reply #12 on: September 13, 2019, 07:23:30 AM »
"Go to Zero" is a system function within Mach3.
I do not see any issues with your XML and it responds normally here.
Perhaps it is associated with your "Xulifeng-Mach3-USB-Motion-Card", assuming there is a plugin for it.
Looks good here otherwise.
« Reply #13 on: September 13, 2019, 07:59:47 AM »
Thank you! Do you think it is plugin related or hardwarerelated? As mentioned , maybe my old plasmacutter with HF ignition damaged the Xulifeng? Still weird that running a g-code works normal and so do the arrow keys.
« Reply #14 on: September 13, 2019, 08:29:02 AM »
 can buy a fairly cheap second hand nvum mach 3 controller. Maybe it's wise to replace the xulifeng by that one?
« Reply #15 on: September 13, 2019, 10:20:47 AM »
when Mach starts it defaults to a low 6% of max speed.
.... actually, it defaults to 6.00 units per min.
Inches would be quite "visible", but mm's would barely creep.
Increase override 200% and that DRO goes to 12  :)
What is showing in the attached pic while your machine is invisibly moving after hitting the "Go to Zero" button ?
« Reply #16 on: September 13, 2019, 12:39:19 PM »
The set feedrate is 1000
Units/min runs between 9000 and 10000
Units/rev is 0
« Reply #17 on: September 13, 2019, 12:44:44 PM »
I really really don't know what i have done but it seems to work fine now.... Maybe I hit the button softlimits but I cannot imagine that did the trick.
« Reply #18 on: September 13, 2019, 01:02:02 PM »
I have to come back to that. As I tried to Ref all Home at a better point on the table and moved evetything afterwards the same problem occurs. I dod ref all home and moved the X and Y in the max position. Pressed.go to zero and it was slow again. to
« Reply #19 on: September 13, 2019, 02:05:51 PM »
I think I figured it out! Each time I change the Ref all Home point on the table, the machine has to run one pass to that point in a very slow mode. Once finished, from that moment on it moves fast and normal.
Can anyone confirm this is normal?
