Hello Guest it is November 13, 2026, 09:47:02 AM
Author Topic: UC300  (Read 20728 times)
UC300
« on: June 26, 2019, 08:44:05 AM »
WHAT IS THE DIFFERENCE BETWEEN UC300 AND UC100  MOTION CONTROLLERS?? I USE THE UC100
LUMBER60
  •  9,377 9,377
Re: UC300
« Reply #1 on: June 26, 2019, 08:57:32 AM »
Perhaps check out the uccnc website, they describe the differences quite well. https://www.cncdrive.com/products.html
Re: UC300
« Reply #2 on: June 26, 2019, 09:06:27 AM »
Re: UC300
« Reply #3 on: June 26, 2019, 05:45:02 PM »
The UC100 has the equivalent pins of one parallel port.
The UC300ETH has 5x the inputs and outputs, has an ethernet connection, higher pulse frequency, and analog inputs and outputs.
Re: UC300
« Reply #4 on: June 27, 2019, 06:56:33 AM »
thanks, that seems like the way to go. That will probably be my next upgrade.
lumber60
Re: UC300
« Reply #5 on: June 27, 2019, 07:45:27 AM »
If you don't need as many ports and pins as the UC300ETH offers, you might want to consider the AXBB-E, which is an all in one breakout board controller.
The UC300ETH requires a breakout board for each port, or a multi port breakout board.
The AXBB-E has screw terminals for all the pins.
Re: UC300
« Reply #6 on: June 27, 2019, 08:17:26 AM »
aah yes information is the key. I will investigate that as well.
lumber60
Re: UC300
« Reply #7 on: June 27, 2019, 08:21:43 AM »
CNC DRIVE SITE MENTIONS MACH 3, WILL THIS AXBB-E FUNCTION WITH MACH 4?
LUMBER60
Re: UC300
« Reply #8 on: June 27, 2019, 09:01:39 AM »
I would email them and ask the status of a Mach4 plugin. I would expect that they are working on it.
You might also ask them if there are any features that their Mach4 plugins don't support.
Re: UC300
« Reply #9 on: June 27, 2019, 09:12:27 AM »
GOT IT,
THANKS
LUMBER60
