Hello Guest it is November 13, 2026, 01:17:30 PM
Author Topic: it is possible with Mach3  (Read 7955 times)
« on: May 02, 2019, 07:39:01 PM »
Greetings to all
I have my CNC router machine. and I ask you if it is possible to do what you see in the video.
the injection is done with pneumatics powered by electrovalves.
the trajectories are generated with Artcam
I'm stuck with the Mach3 I do not know how to do it
any comment I am very attentive.
thank you.
https://www.youtube.com/watch?v=OcTjs1cRt3U
Offline TPS
  •  2,627 2,627
Re: it is possible with Mach3
« Reply #1 on: May 03, 2019, 02:24:40 AM »
i think principialy it should be no Problem
https://www.machsupport.com/forum/index.php?topic=11158.0
https://www.machsupport.com/forum/index.php?topic=35320.msg242125#msg242125
use different work Offsets (G54...) for the different nozzles and M10/M11 to Switch the valves.
« Reply #2 on: May 07, 2019, 08:58:17 PM »
TPS
thank you very much for your help.
I did not know about G54 and I investigated but I did not understand
Greetings to all
