Hello Guest it is November 10, 2026, 01:56:39 AM
Author Topic: macro for 4 slot tool change hep  (Read 70823 times)
« on: April 16, 2019, 06:43:16 AM »
Hi I'm new to macros. and I'm trying to get my atc to work for my lathe. and i need some help
my atc macro. must control the following.
(output 8.) unlock rotates ccw
(output 9) rotate cw for lock
(input 23) lock contact
(input 22) tool 1
(input 21) tool 2
(input 20) tool 3
(input 19) tool 4
i have found a macro that i believe will work but nothing happens when i save it in m6start what am i missing? i have put atc on.
i am also missing the (lock input 23)
OldTool = GetOEMDRO (1200)
Tool = GetSelectedTool()
MaxToolNum = 4      'Max number of tools for the changer
If OldTool = Tool Then
Message ("Selected Tool already loaded")
Exit Sub
End If
While Tool > MaxToolNum
Tool = Question ("Enter New Tool Number up to " & MaxToolNum)
Wend
Call StartTool
While NewTool <> Tool
   Call CheckPins
   While IsMoving()
   Wend
Wend
Call StopTool
Call SetUserDRO (1200, NewTool)
SetCurrentTool(NewTool)
'//// Subroutines /////////
Sub StartTool
   ActivateSignal(Output8)
   'Code "G4 P4.0"    'Wait for the tool to rotate past the sensor
      While IsMoving()
      Wend
End Sub
Sub CheckPins
   If Not IsActive(Input22) Then
      NewTool = 1
      End If
   If Not IsActive(Input21) Then
      NewTool = 2
      End If
   If Not IsActive(Input20) Then
      NewTool = 3
      End If
   If Not IsActive(Input19) Then
      NewTool = 4
      End If
End Sub
Sub Stoptool
   DeActivateSignal(Output8)
      While IsMoving()
      Wend
   ActivateSignal(Output9)
      Code "G4 P1.0"    'Wait for the tool to rotate onto ratchet stop
      While IsMoving()
      Wend
   DeActivateSignal(Output9)
      While IsMoving()
      Wend
End Sub
Offline TPS
  •  2,627 2,627
Re: macro for 4 slot tool change hep
« Reply #1 on: April 16, 2019, 08:07:33 AM »
how do you initiate toolchange
in lathe mode it is
M6 T0101 for example
« Reply #2 on: April 16, 2019, 08:18:40 AM »
in lathe mode it is
i just change the tool nr. from 1-4.
or write m6 t0101 but nothing happens
Offline TPS
  •  2,627 2,627
« Reply #3 on: April 16, 2019, 08:22:45 AM »
add
msgbox ("M6 Start executed")
at the begin of the macro to see that the macro is called
Offline TPS
  •  2,627 2,627
« Reply #4 on: April 16, 2019, 08:25:56 AM »
do you have enabled in
Config -> General Config -> Tool Change -> Auto Tool Change
« Reply #5 on: April 16, 2019, 08:37:25 AM »
add
like this ?
Exit Sub
End If
Wend
Call StartTool
   Call CheckPins
   While IsMoving()
   Wend
Wend
Call StopTool
Sub StartTool
      While IsMoving()
      Wend
End Sub
Sub CheckPins
      NewTool = 1
      End If
      NewTool = 2
      End If
      NewTool = 3
      End If
      NewTool = 4
      End If
End Sub
Sub Stoptool
      While IsMoving()
      Wend
      While IsMoving()
      Wend
      While IsMoving()
      Wend
End Sub
« Reply #6 on: April 16, 2019, 08:40:35 AM »
yes it is on :)
Offline TPS
  •  2,627 2,627
« Reply #7 on: April 16, 2019, 08:50:34 AM »
add
like this ?
Exit Sub
End If
Wend
Call StartTool
   Call CheckPins
   While IsMoving()
   Wend
Wend
Call StopTool
Sub StartTool
      While IsMoving()
      Wend
End Sub
Sub CheckPins
      NewTool = 1
      End If
      NewTool = 2
      End If
      NewTool = 3
      End If
      NewTool = 4
      End If
End Sub
Sub Stoptool
      While IsMoving()
      Wend
      While IsMoving()
      Wend
      While IsMoving()
      Wend
End Sub
yes
Offline TPS
  •  2,627 2,627
« Reply #8 on: April 16, 2019, 08:53:43 AM »
you can copy all your code to
Operator -> VB Scripter Window
and use the >|| button to step through to see what is going on
« Reply #9 on: April 16, 2019, 10:04:07 AM »
my mach 3 just crash when i do that
