Hello Guest it is November 10, 2026, 01:58:13 AM
Author Topic: macro for 4 slot tool change hep  (Read 70825 times)
Re: macro for 4 slot tool change hep
« Reply #20 on: April 25, 2019, 02:48:55 AM »
I have tried the test. And it won't read the input. :(
 but i get the input on the ip-a controller)
« Reply #21 on: April 25, 2019, 03:08:50 AM »
are i missing a mach or a ipa config ?
« Reply #22 on: April 25, 2019, 03:14:23 AM »
hmm
Offline TPS
  •  2,627 2,627
« Reply #23 on: April 25, 2019, 03:35:58 AM »
oh sh**t, missed that we are on a CSMIO Controller, sorry.
here the modified code:
Code: [Select]
OldTool = GetCurrentTool()
Tool = GetSelectedTool()
MaxToolNum = 4      'Max number of tools for the changer
debug = true
If debug = true Then
Message "OldTool: " & OldTool & " NewTool: " & Tool
Sleep(200)
End If
If OldTool = Tool Then
Message ("Selected Tool already loaded")
Exit Sub
End If
While Tool > MaxToolNum
Tool = Question ("Enter New Tool Number up to " & MaxToolNum)
Wend
Call StartTool
While NewTool <> Tool
   Call CheckPins
   While IsMoving()
   Wend
Wend
Call StopTool
SetCurrentTool(NewTool)
'//// Subroutines /////////
Sub StartTool
   ActivateSignal(Output8)
Message "Output8 On"
Sleep(200)
   End If
   'Code "G4 P4.0"    'Wait for the tool to rotate past the sensor
      While IsMoving()
      Wend
End Sub
Sub CheckPins
   If GetCsmioIn(91,6) = True Then
      NewTool = 1
      End If
   If GetCsmioIn(91,5) = True Then
      NewTool = 2
      End If
   If GetCsmioIn(91,4) = True Then
      NewTool = 3
      End If
   If GetCsmioIn(91,3) = True Then
      NewTool = 4
      End If
Message "NewTool= " & NewTool
Sleep(200)
  End If
End Sub
Sub Stoptool
   DeActivateSignal(Output8)
Message "Output8 Off"
Sleep(200)
   End If
      While IsMoving()
      Wend
   ActivateSignal(Output9)
Message "Output9 On"
Sleep(200)
   End If
      Code "G4 P1.0"    'Wait for the tool to rotate onto ratchet stop
      While IsMoving()
      Wend
   DeActivateSignal(Output9)
Message "Output9 Off"
Sleep(200)
   End If
      While IsMoving()
      Wend
End Sub
'CSMIO Eingang lesen
Function GetCsmioIn (ByVal adr As Integer, ByVal n As Integer) As Boolean
If(GetInBit(adr, n)) Then
GetCsmioIn = true
Else
GetCsmioIn = false
End If
End Function
Offline TPS
  •  2,627 2,627
« Reply #24 on: April 25, 2019, 03:37:23 AM »
« Reply #25 on: April 25, 2019, 04:49:11 AM »
that is a different ball game  ;)
now it works almost as intended.
it is possible to get output 8 to stop faster.
Half of the time it jumps over the tool and locks on the next tool. no error ditekted
perhaps a security system to lock.
 i have a micro swich on input23 which indicates the spindel is locked.
in the locked state, the tool number is on(input19-22) and Safety lock (input23) is on.
if not rotate again (outout 8 )
Offline TPS
  •  2,627 2,627
« Reply #26 on: April 25, 2019, 05:08:47 AM »
here a new Version.
-all debug code deleted (faster Operation)
-Input 23 now used to stop reverse run
-after finish re check and retry
Code: [Select]
Exit Sub
End If
If Tool > MaxToolNum Then
End If
doagain:
Call StartTool
   Call CheckPins
Wend
Call StopTool
're check
Call CheckPins
If NewTool <> Tool Then
goto doagain
End If
Sub StartTool
End Sub
Sub CheckPins
      NewTool = 1
      End If
      NewTool = 2
      End If
      NewTool = 3
      End If
      NewTool = 4
      End If
End Sub
Sub Stoptool
   'wait for input 23
   While GetCsmioIn(91,7) = True
Sleep(20)
   Wend
End Sub
GetCsmioIn = true
Else
GetCsmioIn = false
End If
End Function
Offline TPS
  •  2,627 2,627
« Reply #27 on: April 25, 2019, 05:13:30 AM »
sorry
Needs to be
While GetCsmioIn(91,7) = False
« Reply #28 on: April 25, 2019, 06:20:20 AM »
it works
But the security lock needs an extra thing. :)
if I disassemble (input23) the spindle continues to drive up against the lock. it is OK
but it must stop after 3 sec. and activate a fault atc not locked (estop) otherwise i think the engine will burn :)
Offline TPS
  •  2,627 2,627
« Reply #29 on: April 26, 2019, 01:24:38 AM »
ok sorry for the delay.
here the code with a 3 second timeout for input23
Code: [Select]
Sub Main
'//Declarations
Dim StartTime, ActTime As Single
Exit Sub
End If
End If
doagain:
Call StartTool
Call CheckPins
Wend
Call StopTool
're check
Call CheckPins
goto doagain
End If
End Sub
Sub StartTool
End Sub
Sub CheckPins
      NewTool = 1
      End If
      NewTool = 2
      End If
      NewTool = 3
      End If
      NewTool = 4
      End If
End Sub
Sub Stoptool
   'wait for input 23   or timeout
StartTime = Timer
Sleep(20)
ActTime = Timer
If ActTime > StartTime + 3 Then
MsgBox "Timeout Input23!!"
DoButton(3)
Sleep(300)
Exit Sub
End If
   Wend
End Sub
GetCsmioIn = true
Else
GetCsmioIn = false
End If
End Function
IMHO i think for a save TC on a lathe some more things are necessary.
1. homing Limit Switches
   machine should have homing Limits to have the possibillity to drive TC to a defined Position
   (in machine coords) to be save for rotate the TC
here some code witch check' that X and Y axis are referenced
Code: [Select]
'X-Axis not in reference
If GetOEMLED(807) Then
DoButton(3)
Sleep(500)
Message ("X-Axis not referenced -> Abort !!")
Exit Sub
End If
'Z-Axis not in reference
If GetOEMLED(809) Then
DoButton(3)
Sleep(500)
Message ("Z-Axis not referenced -> Abort !!")
Exit Sub
End If
2. drive Z and X axis to a defined Position (in machine coords)
here some code:
Code: [Select]
Message "ATC X-Axis to TC position"
Code "G90 G53 G0 X2"
While IsMoving()
Sleep(15)
Wend
Message "ATC Z-Axis to TC position"
Code "G90 G53 G0 Z2"
While IsMoving()
Sleep(15)
Wend
