Hello Guest it is November 10, 2026, 01:58:20 AM
Author Topic: macro for 4 slot tool change hep  (Read 70826 times)
Offline TPS
  •  2,627 2,627
Re: macro for 4 slot tool change hep
« Reply #10 on: April 16, 2019, 12:46:51 PM »
ok, not good,
give me pls some more Information about your complete System.
Thomas
« Reply #11 on: April 16, 2019, 04:21:24 PM »
ok, not good,
Thomas
hello
it is a Avon 5500 cnc Rebild
with a cismo ip- controller running mach 3 lates version.
i just downloadet march to a different pc. copied the macro in to vb skript same result, vb crashes.
Offline TPS
  •  2,627 2,627
« Reply #12 on: April 17, 2019, 12:36:07 AM »
strange.
i have tested the code here on a
Version R3.043.066 and
Version R3.043.022
both with a CSMIO -IP S
and no Problem.
try to copy line by line to the VB scripter window
« Reply #13 on: April 24, 2019, 07:46:51 AM »
Hello again. I am sorry for the late reply.
I have caused the system to not break down.
when I run the code with T0101m6 I only get activated (output 9).
  I've tried to change
(If Not IsActive (Input22) Then
       NewTool = 1)
to
(If IsActive (Input22) Then
       NewTool = 1)
It should be right in my case.
But nothing happens spindel just keep rotating :(
Offline TPS
  •  2,627 2,627
« Reply #14 on: April 24, 2019, 11:18:14 AM »
try this code, now you should see in Status line witch TC place is detected by the Inputs
Code: [Select]
OldTool = GetCurrentTool()
Tool = GetSelectedTool()
MaxToolNum = 4      'Max number of tools for the changer
Message "OldTool: " & OldTool & " NewTool: " & Tool
Sleep(200)
If OldTool = Tool Then
Message ("Selected Tool already loaded")
Exit Sub
End If
While Tool > MaxToolNum
Tool = Question ("Enter New Tool Number up to " & MaxToolNum)
Wend
Call StartTool
While NewTool <> Tool
   Call CheckPins
   While IsMoving()
   Wend
Wend
Call StopTool
SetCurrentTool(NewTool)
'//// Subroutines /////////
Sub StartTool
   ActivateSignal(Output8)
   'Code "G4 P4.0"    'Wait for the tool to rotate past the sensor
      While IsMoving()
      Wend
End Sub
Sub CheckPins
   If IsActive(Input22) Then
      NewTool = 1
      End If
   If IsActive(Input21) Then
      NewTool = 2
      End If
   If IsActive(Input20) Then
      NewTool = 3
      End If
   If IsActive(Input19) Then
      NewTool = 4
      End If
  Message "NewTool= " & NewTool
  Sleep(200)
End Sub
Sub Stoptool
   DeActivateSignal(Output8)
      While IsMoving()
      Wend
   ActivateSignal(Output9)
      Code "G4 P1.0"    'Wait for the tool to rotate onto ratchet stop
      While IsMoving()
      Wend
   DeActivateSignal(Output9)
      While IsMoving()
      Wend
End Sub
« Last Edit: April 24, 2019, 11:20:11 AM by TPS »
« Reply #15 on: April 24, 2019, 02:40:20 PM »
hi
i dont think the macro can detect the input.
i set input 22 to input 4 in my system witch is always aktive. an the macro cant detect that ether.
Offline TPS
  •  2,627 2,627
« Reply #16 on: April 25, 2019, 01:40:16 AM »
added some more debug info in this code. pls run this code and (assume you use Mach3 Standard
turn screenset) go to Diags. an use the History Button.
post the Textfile after running the macro.
Code: [Select]
debug = true
If debug = true Then
Sleep(200)
End If
Exit Sub
End If
Wend
Call StartTool
   Call CheckPins
   While IsMoving()
   Wend
Wend
Call StopTool
Sub StartTool
Message "Output8 On"
Sleep(200)
   End If
      While IsMoving()
      Wend
End Sub
Sub CheckPins
      NewTool = 1
      End If
      NewTool = 2
      End If
      NewTool = 3
      End If
      NewTool = 4
      End If
Sleep(200)
  End If
End Sub
Sub Stoptool
Message "Output8 Off"
Sleep(200)
   End If
      While IsMoving()
      Wend
Message "Output9 On"
Sleep(200)
   End If
      While IsMoving()
      Wend
Message "Output9 Off"
Sleep(200)
   End If
      While IsMoving()
      Wend
End Sub
« Reply #17 on: April 25, 2019, 01:45:56 AM »
  I want to make sure my imput is working properly.
I want to try with a simple macro.
ActivateSignal(Output8) when (input 22) is on then DeActivateSignal(Output8)
is this correkt ?
End if
« Reply #18 on: April 25, 2019, 01:48:36 AM »
ok i will go out and Try it now
Offline TPS
  •  2,627 2,627
« Reply #19 on: April 25, 2019, 01:54:40 AM »
Code: [Select]
While NOT IsActive(Input22)
Sleep(50)
Wend
would be the code for a simple test
