Hello Guest it is November 10, 2026, 01:57:50 AM
Author Topic: macro for 4 slot tool change hep  (Read 70824 times)
Re: macro for 4 slot tool change hep
« Reply #30 on: April 26, 2019, 03:22:45 AM »
hi there must be a small error in the last post on input 23
the most frustrating ting i have with my system, is every time i rum VB code, with an error. VB locks down  and i need to restart my hole system.
it dossent lave much for troubleshooting.
I have deliberately failed to include the x-z axis movement as I cannot test it yet.
my drives are on the way:)
Offline TPS
  •  2,627 2,627
« Reply #31 on: April 26, 2019, 03:31:55 AM »
you mean the last code with the timeout included?
do you get any message in the statusline?
very hard to test here without the real Hardware.
Offline TPS
  •  2,627 2,627
« Reply #32 on: April 26, 2019, 03:37:33 AM »
ok mistake found.
Code: [Select]
Public NewTool As Integer
Sub Main
'//Declarations
Dim StartTime, ActTime As Single
MaxToolNum = 4      'Max number of tools for the changer
OldTool = GetCurrentTool()
Tool = GetSelectedTool()
If OldTool = Tool Then
Message ("Selected Tool already loaded")
Exit Sub
End If
If Tool > MaxToolNum Then
Tool = Question ("Enter New Tool Number up to " & MaxToolNum)
End If
doagain:
Call StartTool
While NewTool <> Tool
Call CheckPins
Wend
Call StopTool
're check
Call CheckPins
If NewTool <> Tool Then
GoTo doagain
End If
SetCurrentTool(NewTool)
End Sub
'//// Subroutines /////////
Sub StartTool
   ActivateSignal(Output8)
End Sub
Sub CheckPins
   If GetCsmioIn(91,6) = True Then
      NewTool = 1
      End If
   If GetCsmioIn(91,5) = True Then
      NewTool = 2
      End If
   If GetCsmioIn(91,4) = True Then
      NewTool = 3
      End If
   If GetCsmioIn(91,3) = True Then
      NewTool = 4
      End If
End Sub
Sub Stoptool
   DeActivateSignal(Output8)
   ActivateSignal(Output9)
   'wait for input 23 or timeout
StartTime = Timer
   While GetCsmioIn(91,7) = False
Sleep(20)
ActTime = Timer
If ActTime > StartTime + 3 Then
MsgBox "Timeout Input23!!"
DeActivateSignal(Output9)
DoButton(3)
Sleep(300)
Exit Sub
End If
   Wend
End Sub
'CSMIO Eingang lesen
Function GetCsmioIn (ByVal adr As Integer, ByVal n As Integer) As Boolean
If(GetInBit(adr, n)) Then
GetCsmioIn = true
Else
GetCsmioIn = false
End If
End Function
« Reply #33 on: April 26, 2019, 03:57:54 AM »
nice it registered the error. but the relay is still on until i hit the ok one the message box. it must somehow deactivate relay 9 again. without having to press ok first. :)
Offline TPS
  •  2,627 2,627
« Reply #34 on: April 26, 2019, 04:06:16 AM »
Code: [Select]
Sub Main
'//Declarations
Exit Sub
End If
End If
doagain:
Call StartTool
Call CheckPins
Wend
Call StopTool
're check
Call CheckPins
GoTo doagain
End If
End Sub
Sub StartTool
End Sub
Sub CheckPins
      NewTool = 1
      End If
      NewTool = 2
      End If
      NewTool = 3
      End If
      NewTool = 4
      End If
End Sub
Sub Stoptool
StartTime = Timer
Sleep(20)
ActTime = Timer
DoButton(3)
Sleep(300)
Exit Sub
End If
   Wend
End Sub
GetCsmioIn = true
Else
GetCsmioIn = false
End If
End Function
« Reply #35 on: April 26, 2019, 05:01:38 AM »
it works like a charme  8)
the macros you posted on axis movement. i only need to juse one ?
and put it before pressent macro. is this correkt ?
Offline TPS
  •  2,627 2,627
« Reply #36 on: April 26, 2019, 05:16:41 AM »
this would bo the complete code, with refernce check and X/Z move.
Code: [Select]
Sub Main
'//Declarations
Exit Sub
End If
End If
'X-Axis not in reference
If GetOEMLED(807) Then
DoButton(3)
Sleep(500)
Message ("X-Axis not referenced -> Abort !!")
Exit Sub
End If
'Z-Axis not in reference
If GetOEMLED(809) Then
DoButton(3)
Sleep(500)
Message ("Z-Axis not referenced -> Abort !!")
Exit Sub
End If
Message "ATC X-Axis to TC position"
Code "G90 G53 G0 X2"
While IsMoving()
Sleep(15)
Wend
Message "ATC Z-Axis to TC position"
Code "G90 G53 G0 Z2"
While IsMoving()
Sleep(15)
Wend
doagain:
Call StartTool
Call CheckPins
Wend
Call StopTool
're check
Call CheckPins
GoTo doagain
End If
End Sub
Sub StartTool
End Sub
Sub CheckPins
      NewTool = 1
      End If
      NewTool = 2
      End If
      NewTool = 3
      End If
      NewTool = 4
      End If
End Sub
Sub Stoptool
StartTime = Timer
Sleep(20)
ActTime = Timer
DoButton(3)
Sleep(300)
Exit Sub
End If
   Wend
End Sub
GetCsmioIn = true
Else
GetCsmioIn = false
End If
End Function
IMPORTANT:
it will move first X than Z axis!
the values of this two code lines:
are in machine coord's and maybe Need to be adjusted.
« Reply #37 on: April 29, 2019, 02:11:00 AM »
ok thanks. i will try it out when I receive the drives.  ;)
