Hello Guest it is November 22, 2026, 02:28:11 PM
Author Topic: g-code post processor error  (Read 8518 times)
« on: January 23, 2019, 09:30:08 PM »
Hi Guys,
Whenever I post process,  the processor is trying to move the XY before lifting the Z axis,  same as return.  EG Below:
Start
"(T1  D=6. CR=0. - ZMIN=-27. - FLAT END MILL)
G90 G94 G91.1 G40 G49 G17
G21
G28 G91 Z0.
G90
(2D POCKET1 3)
M5
M9
T1 M6
S17585 M3
G54
G0 X-39.903 Y41.183
G43 Z5. H1
G1 Z-1.4 F557. "
Obviously,  this crashes into the part and stuff a few good cuts,  I was wondering if there is a way to fix this without editing every bit of g code i create in the editor ?
  •  9,378 9,378
Re: g-code post processor error
« Reply #1 on: January 24, 2019, 12:44:09 AM »
Which CAD/CAM and which Post Processor?
Are you using Mach3 or Mach4 ?
« Reply #2 on: January 24, 2019, 04:35:13 PM »
I'm using fusion 360 with Mach3 and inbuilt Mach3 processors.
  •  9,378 9,378
« Reply #3 on: January 25, 2019, 01:45:37 AM »
You could use the Mach3 Safe_Z Setup (Config. menu) or modify your Post Processor.
Safe_Z is probably the easiest solution.
