Hello
Guest
it is
November 13, 2026, 01:16:41 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
Go Down
Author
Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA (Read 293137 times)
Davek0974
2,606
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
Reply #160 on:
February 27, 2018, 03:48:10 PM »
Pierce height should be in the g-code IIRC
LexMotorsports
133
Reply #161 on:
February 27, 2018, 03:53:46 PM »
MACH is applying random numbers to my Z offset. I don’t know what is going on
LexMotorsports
133
Reply #162 on:
February 27, 2018, 03:57:12 PM »
The probe isn’t operating correctly anymore, it’s not raising Z to go to pierce height after probing, it’s driving down into the material.
TPS
2,627
Reply #163 on:
February 27, 2018, 04:36:18 PM »
ok let's get back to the Basics,
open up vb scirper window
copy this code:
pierceHeight = 0.5 'enter here a value for wanted pierceheiht
code "F30"
code "G31 Z-1"
While Ismoving()
Wend
code "G00 Z" & GetVar(2002) 'go back to the probepoint
While Ismoving()
Wend
code "G91 Z-" & pierceHeight
While Ismoving()
Wend
code "G92 Z0"
While Ismoving()
Wend
Code "G90"
and use the ||> green buton to se what's goinng on
LexMotorsports
133
Reply #164 on:
February 27, 2018, 05:11:48 PM »
It probes good, then dives at g91. I changed 2002 to 0, then re ran, it got all the way passed g91 z- (at this point it was back at Z 0) then it dove .5” down instead of rising .5” up
TPS
2,627
Reply #165 on:
February 28, 2018, 12:59:14 AM »
sorry should be
code "G91 Z" & pierceHeight
LexMotorsports
133
Reply #166 on:
February 28, 2018, 10:22:19 AM »
That fixed the probing issue, still having the same issue with the THC.
TPS
2,627
Reply #167 on:
February 28, 2018, 10:46:25 AM »
is Torch DN in dignosic Screen defenitiv off?
LexMotorsports
133
Reply #168 on:
February 28, 2018, 10:47:15 AM »
Really interesting, on my second pierce, when it goes to probe it changed my cutting speed From 130 ipm to 30 ipm.?
LexMotorsports
133
Reply #169 on:
February 28, 2018, 10:48:32 AM »
Quote from: TPS on February 28, 2018, 10:46:25 AM
I don’t understand.. sorry
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
Go Up
« previous
next »
