Hello Guest it is November 13, 2026, 01:08:49 PM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 293123 times)
0 Members and 6 Guests are viewing this topic.
Offline Davek0974
  •  2,606 2,606
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #160 on: February 27, 2018, 03:48:10 PM »
Pierce height should be in the g-code IIRC
« Reply #161 on: February 27, 2018, 03:53:46 PM »
MACH is applying random numbers to my Z offset. I don’t know what is going on
« Reply #162 on: February 27, 2018, 03:57:12 PM »
The probe isn’t operating correctly anymore, it’s not raising Z to go to pierce height after probing, it’s driving down into the material.
Offline TPS
  •  2,627 2,627
« Reply #163 on: February 27, 2018, 04:36:18 PM »
ok let's get back to the Basics,
open up vb scirper window
copy this code:
pierceHeight = 0.5 'enter here a value for wanted pierceheiht
   code "F30"
   code "G31 Z-1"
   While Ismoving()
   Wend
   code "G00 Z" & GetVar(2002) 'go back to the  probepoint
   While Ismoving()
   Wend
   code "G91 Z-" & pierceHeight
   While Ismoving()
   Wend
   code "G92 Z0"
   While Ismoving()
   Wend
   Code "G90"
and use the ||> green buton to se what's goinng on
« Reply #164 on: February 27, 2018, 05:11:48 PM »
It probes good, then dives at g91. I changed 2002 to 0, then re ran, it got all the way passed g91 z- (at this point it was back at Z 0) then it dove .5” down instead of rising .5” up
Offline TPS
  •  2,627 2,627
« Reply #165 on: February 28, 2018, 12:59:14 AM »
sorry should be
code "G91 Z" & pierceHeight
« Reply #166 on: February 28, 2018, 10:22:19 AM »
That fixed the probing issue, still having the same issue with the THC.
Offline TPS
  •  2,627 2,627
« Reply #167 on: February 28, 2018, 10:46:25 AM »
is Torch DN in dignosic Screen defenitiv off?
« Reply #168 on: February 28, 2018, 10:47:15 AM »
Really interesting, on my second pierce, when it goes to probe it changed my cutting speed From 130 ipm  to 30 ipm.?
« Reply #169 on: February 28, 2018, 10:48:32 AM »
I don’t understand.. sorry
