Hello Guest it is November 13, 2026, 02:02:48 PM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 293197 times)
Offline Davek0974
  •  2,606 2,606
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #180 on: February 28, 2018, 01:05:24 PM »
everything seems ffine to me,..,
Code: [Select]
N0010 (Filename: 1.tap)
N0020 (Post processor: Mach3 plasma.scpost)
N0030 (Date: 28/02/2018)
N0040 G20 (Units: Inches)
N0050 G53 G90 G91.1 G40
N0060 F1
N0070 S500
N0080 (Part: 1)
N0090 (Operation: Outside Offset, LAYER_1, T1: Plasma, 0.0561 in kerf)
N0100 M06 T1 F80.0  (Plasma, 0.0561 in kerf)
N0110 G00 Z1.0000
N0120 X0.6134 Y0.6013
N0130 Z0.0000
N0140 M03
N0150 G03 X0.7726 Y0.6873 I0.0366 J0.1227 F80.0
N0160 X0.7726 Y0.6873 I-0.2726 J0.0813
N0170 X0.6865 Y0.8466 I-0.1227 J0.0366
N0180 M05
N0190 G00 Z1.0000
N0200 X1.1256 Y-0.1384
N0210 Z0.0000
N0220 M03
N0230 G03 X0.9976 Y-0.0104 I-0.1280 J0.0000
Hmm, N0100 & N0130 items seem odd to me
Tool change is not usually used in plasma, why is it going to Z0 before the pierce??
You should never, pierce at zero height, unless this is a scratch-start plasma??
« Reply #181 on: February 28, 2018, 01:18:43 PM »
ok this code should work, and restore original feedrate
pierceHeight = 0.5 'enter here a value for wanted pierceheiht
   orgspeed=GetDro(18)
   code "F30"
   code "G31 Z-1"
   While Ismoving()
   Wend
   code "G00 Z" & GetVar(2002) 'go back to the  probepoint
   While Ismoving()
   Wend
   code "G91 Z" & pierceHeight
   While Ismoving()
   Wend
   code "G92 Z0"
   While Ismoving()
   Wend
   Code "G90"
   Code "F" & orgspeed
Is this necessary? I have my my plunge rate in sheetcam set at 20ipm.
« Reply #182 on: February 28, 2018, 01:19:31 PM »
Code: [Select]
N0060 F1
N0070 S500
N0080 (Part: 1)
N0110 G00 Z1.0000
N0130 Z0.0000
N0140 M03
N0180 M05
N0190 G00 Z1.0000
N0210 Z0.0000
N0220 M03
My pierce height says 0” in sheetcam, because with the edited m3 macro, i was having to control the pierce height in there.
Offline TPS
  •  2,627 2,627
« Reply #183 on: February 28, 2018, 01:20:16 PM »
ok ihave run your code on my PP testmachine.
deleted N100 toolchange not necesary.
run it with THC on but no Inputs connected. everything was ok.
can you for a test disconnect the THC Up/dn Inputs , but physicaly disconnect them.
Offline TPS
  •  2,627 2,627
« Reply #184 on: February 28, 2018, 01:22:08 PM »
   orgspeed=GetDro(18)
   code "F30"
   code "G31 Z-1"
   While Ismoving()
   Wend
   While Ismoving()
   Wend
   While Ismoving()
   Wend
   code "G92 Z0"
   While Ismoving()
   Wend
   Code "G90"
   Code "F" & orgspeed
yes because you have a "variable" cuttin feedrate but probing feedrate should allways be the same.
« Reply #185 on: February 28, 2018, 01:24:00 PM »
So leave THC on, and inputs active, but physically remove the inputs into my g540?
Offline TPS
  •  2,627 2,627
« Reply #186 on: February 28, 2018, 01:25:59 PM »
exactly
Offline TPS
  •  2,627 2,627
« Reply #187 on: February 28, 2018, 01:27:36 PM »
sorry i modified N100 to N100 F80 to Keep the fedrate
Offline TPS
  •  2,627 2,627
« Reply #188 on: February 28, 2018, 01:29:25 PM »
but disconnect only THC UP/Down inputs
« Reply #189 on: February 28, 2018, 01:30:31 PM »
Does the tool change code matter? It’s being generated by itself, but in MACH, my “ignore tool change” setting is checked. It has never been an issue
