Hello Guest it is October 21, 2026, 10:51:32 AM
Author Topic: One side of X axis not in sync with opposite side. Jerky movement  (Read 8908 times)
All, the X axis appears to be jerky. 1 side is smooth, opposite side is jerking trying to catch up. Unuseable at the moment, any ideas where to look?
Thank you
Mike
« Last Edit: July 11, 2017, 11:51:15 AM by CSMG »
Re: One side of X axis not in sync with opposite side. Jerky movement
« Reply #1 on: July 11, 2017, 11:55:40 AM »
is it a mechanical issue or an electrical issue?
what is your setup?
has it been previously working?
« Reply #2 on: July 11, 2017, 03:19:11 PM »
Thanks for the reply. I don't know yet. This is the first time that this has happened.  I am going to take the coveres off and take the steppers off to see if they spin freely.   While it is on the machine and in place,  it is acting spuratic.
I will see what is happening and write back.
« Reply #3 on: July 18, 2017, 12:17:23 AM »
I'm having the same issues with my Y axis. I don't know much about my machine, but if I'm experimenting with my MOTOR TUNING to see if that helps. I wish i could be a better help, good luck!
« Reply #4 on: July 18, 2017, 07:03:32 AM »
I found the issue, one of the drivers on y was bad.
