Hello
Guest
it is
October 21, 2026, 11:33:50 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
One side of X axis not in sync with opposite side. Jerky movement
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: One side of X axis not in sync with opposite side. Jerky movement (Read 8909 times)
CSMG
5
on:
July 11, 2017, 11:46:22 AM »
All, the X axis appears to be jerky. 1 side is smooth, opposite side is jerking trying to catch up. Unuseable at the moment, any ideas where to look?
Thank you
Mike
Last Edit: July 11, 2017, 11:51:15 AM by CSMG
Logged
benjamint76
22
Re: One side of X axis not in sync with opposite side. Jerky movement
Reply #1 on:
July 11, 2017, 11:55:40 AM »
is it a mechanical issue or an electrical issue?
what is your setup?
has it been previously working?
Logged
CSMG
5
Reply #2 on:
July 11, 2017, 03:19:11 PM »
Thanks for the reply. I don't know yet. This is the first time that this has happened. I am going to take the coveres off and take the steppers off to see if they spin freely. While it is on the machine and in place, it is acting spuratic.
I will see what is happening and write back.
Logged
originalsigns
10
Reply #3 on:
July 18, 2017, 12:17:23 AM »
I'm having the same issues with my Y axis. I don't know much about my machine, but if I'm experimenting with my MOTOR TUNING to see if that helps. I wish i could be a better help, good luck!
Logged
CSMG
5
Reply #4 on:
July 18, 2017, 07:03:32 AM »
I found the issue, one of the drivers on y was bad.
Logged
Print
Pages:
1
Go Up
« previous
next »
