Hello Guest it is November 13, 2026, 03:48:21 PM
Author Topic: Need setup help for smoothstepper and C25S BOB  (Read 46977 times)
« on: August 28, 2016, 01:29:58 PM »
Ok I got the C25S plugged into my smoothstepper.  Smoothstepper is configured with my network card and seems to be recognized in mach4 but I need to know what to set in the smoothstepper and Mach configuration in mach4.  As is my motors will not respond to jog but they are locked so I know they are getting signals.  I looked at one of the videos from  Daz but the smoothstepper he used in the video was an early version so all the configuration screens were different.  I have the latest versions of everything.  Below is my system.
I have (5) Gecko 251S drivers for XYZAB axis and they are connected according to Gecko instructions.
Smoothstepper board NOTE: I do not know lf the jumpers are set right so I left them as received.
C25S BOB with port (1) configured as pin 2/3 X pin 4/5 Y pin 6/7 Z pin 8/9 A pin 1/17 B
NEMA 17 motors
I think I covered everything hopefully someone can help me with the correct settings.
  •  9,377 9,377
  •  9,377 9,377
Re: Need setup help for smoothstepper and C25S BOB
« Reply #2 on: August 29, 2016, 05:51:32 AM »
http://www.machsupport.com/forum/index.php/topic,32306.msg230409.html#msg230409
http://www.machsupport.com/forum/index.php/topic,33182.msg230410.html#msg230410
« Reply #3 on: August 29, 2016, 06:51:05 AM »
The ESS settings information is here http://www.warp9td.com/index.php/gettingstarted/setting-up-the-smoothstepper-and-mach4#MachFourInitialESS_NEW_PLUGIN
Yeah I tried using the procedure in that link but the screens images are not the same as that of the latest plugin.
I'm using the 6 axis screen profile that comes with Mach4.
« Last Edit: August 29, 2016, 06:54:32 AM by Christine88 »
« Reply #4 on: August 29, 2016, 06:56:40 AM »
I have jumpers 2 3 4 set.  Jumper 1 is unjumpered.
  •  9,377 9,377
« Reply #5 on: August 29, 2016, 06:58:55 AM »
Correct.
« Reply #6 on: August 29, 2016, 07:01:24 AM »
Correct.
Is there an updated Smoothstepper procedure for the latest plugin 186?
  •  9,377 9,377
« Reply #7 on: August 29, 2016, 07:16:17 AM »
It is my understanding that it is the latest documentation which is linked above (Andy is probably working on the update but everything takes it’s time).
Have you tried using the SCU ?
« Reply #8 on: August 29, 2016, 07:39:44 AM »
I did run that but I forget now what it does.
« Reply #9 on: August 29, 2016, 07:55:36 AM »
Well unless I have relevant procedure I'm left to guessing and that's not going to work.  I just don't know enough about this stuff to make guesses.
