Hello Guest it is November 13, 2026, 03:48:45 PM
Author Topic: Need setup help for smoothstepper and C25S BOB  (Read 46980 times)
Re: Need setup help for smoothstepper and C25S BOB
« Reply #30 on: August 31, 2016, 07:12:21 PM »
This is possibly the best way of showing so started a new set of vids just for forum answers.
https://youtu.be/yRF16VmeVPE
Here is a very quick way of doing the X Axis (Motor 0) you will have to do same with all other motors.
DazTheGas
It works!  I turned on my PC today and tried moving the X axis and it jogged but it will only jog in one direction with X- or X+ and if I click X- even in incremental mode the axis just keep turning but with X+ it moves incrementally.
« Reply #31 on: September 01, 2016, 02:40:00 PM »
That sounds like the X Step connection is working but the X Direction connection is not.
That has happened to me before.
« Reply #32 on: September 01, 2016, 02:41:03 PM »
What was your fix?
« Reply #33 on: September 01, 2016, 02:59:06 PM »
It was a careful checking of the output of pin 3, as well as all of the ESS and Mach4 settings relating to X Dir signal.
It was so long ago now that I can't remember whether it was a wiring problem or software settings problem, but I got it working again by checking the wiring first, then software.
  •  9,377 9,377
« Reply #34 on: September 02, 2016, 02:17:50 AM »
