Hello Guest it is October 20, 2026, 02:55:30 PM
Author Topic: Novice to Mach3, may be asking too much??  (Read 73182 times)
Re: Novice to Mach3, may be asking too much??
« Reply #40 on: July 27, 2016, 04:02:00 PM »
thank you for taking the time to show me how to go on. I confess I'm going to need to spend some time looking at the brains side of it. there doesn't seem to be enough information in the string to work at first glance, but that's me not understanding what I'm looking at!!
« Reply #41 on: July 27, 2016, 04:32:25 PM »
pictures I hope
« Reply #42 on: July 27, 2016, 04:35:05 PM »
3
« Reply #43 on: July 27, 2016, 04:36:24 PM »
4
« Reply #44 on: July 27, 2016, 04:37:51 PM »
5
« Reply #45 on: July 27, 2016, 04:41:34 PM »
god that's hard work.
so machine has a manual Dorean indexer on, in generally good condition
« Reply #46 on: July 27, 2016, 04:42:24 PM »
the existing control was nonfunctional, with support available minimal
« Reply #47 on: July 27, 2016, 04:46:06 PM »
I've plenty of work for the next few evenings, wiring up the old to the new and tidying things up
« Reply #48 on: July 27, 2016, 04:58:37 PM »
You can add 4 pics per post, just click the more attachments text for each pic you want to add.
I will do a quick vid and upload to youtube to let you see how the brain is working.
In the vid I will just emulate an input via my keyboard and set it up in the brain to do a feedhold if it is seen. I will then look at the feedhold LED in Mach and if it is seen then it will turn on an output, that output would work your panel LED.
« Reply #49 on: July 27, 2016, 05:19:37 PM »
Ok here you go.
https://youtu.be/OgGy_G7Eadk
